Results 1 to 3 of 3
Thread: A/C Smell after use
    VY V6 Wagon
    May 2009
    Tauranga NZ
    Default A/C Smell after use
    Howdy - I think this is common to all cars that the air smells coming out of the vents after the A/C is turned off. I believe the evaporator needs a clean, with bacteria etc in the ducts. I have seen a spray can to fix it but does it work? Also is giving the evap a good old clean a DIY job if so where is the thing??
    VZ Exec
    Nov 2009
    Brizzy
    Yeah I think it's a common problem, but some (older units I spose) are worse than others. I usually turn the aircon off and leave the blower going 2 minutes before home, gets the smell out.
    If you come up with anything that helps mate, plz post.... Your bacteria theory scares me tho, hello legionella :$
    VY Berlina 02 V6
    Jun 2009
    About 7 weeks ago i had mine looked at as it was not working and when i got the car back it did stink as well. After a number of days it dont stink no more at all and you can get some stuff thats ment to stop them from stinking from were you get your aircon serviced at. I do try and run the fan most of the time just befor i get home to dry it out. But if its hot i just let it run till home with no problems at all
  1. Best 'New Car Smell'
    By Denno in forum General
    Last Post: 30-05-2008, 10:15 PM
  2. VS Smell
    By Holden V8 SS Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2008, 02:20 AM
  3. Spew smell
    By Noy in forum General
    Last Post: 07-04-2007, 12:56 AM
  4. New car smell
    By ClairBear in forum General
    Last Post: 06-06-2006, 01:49 AM
  5. Air Con Smell
    By sittingduckau in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-01-2006, 03:19 PM
