Results 1 to 8 of 8
Thread: What is this and how do I replace it?
    wetwork65's Avatar
    wetwork65 is offline A wet business
    VY Berlina V8 & VZ Adventra LX8
    Mar 2006
    With the goblins in South West WA
    Default What is this and how do I replace it?
    This small rubber elbow - goes into the intake area - has developed a hole and is making a loud hissing noise.
    Engine check warning is on intermittently as well.
    How do I describe it to get a new one and how do I fit it?
    I have wrapped tape around it at the moment.
    Thanks for help
    Attached Thumbnails Attached Thumbnails What is this and how do I replace it?-img_3253.jpg
    VY SII HBD Calais L67
    Dec 2006
    I think it's the PCV hose. Go to holden and they'll have a diagram for you to point it out on before you order
    VYII Calais L67
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Quote Originally Posted by chargedvx6 View Post
    Yes its the PCV valve to inlet manifold hose- the heat from the manifold hardens the rubber over time & they fail. If you peel back the larger rubber cover you will find the PCV valve under it. Worthwhile to check it too for blockages , they tend to gunk up . immerse it in petrol for an hour then shake it out , you should be able to blow freely thru it one way but its restricted the other. Make sure you put it back in the line the right way around too (mark one end when you take it off....)
    HoldrodeoLT's Avatar
    HoldrodeoLT is offline I have no lemon pledge...
    2004 Holden Rodeo RA LT, 2008 Polaris Hawkeye 300
    Aug 2008
    The engine light coming on is because of the leak, it's getting an incorrect fuel mixture...
    About as handy as tits on a bull
    wetwork65's Avatar
    Mar 2006
    Thanks for the replies - genuine part is $70 - have to buy the whole tube to the back of the motor. But this is better than the current 5 layers of insulating tape!
    That would make sense - mixture too lean.
    BTW - the hissing noise was as loud as the proverbial - sounded like a bearing gone. Gave the wife some cause for concern.
    Sep 2007
    Cool
    Quote Originally Posted by wetwork65 View Post
    -But still better than the wife hissing , hey!!!!!!!!
    wetwork65's Avatar
    Mar 2006
    Fitted the part in about 10 minutes - not even enough time for one beer.
    Oh and the RAC guy told my wife yesterday that the computer was the problem you will need the car towed or drive carefully 30 minutes to the nearest holden dealer. Yeah right I'll do that......
    Sep 2007
    Good work, just shows you the standard of technical skills around , it's like trying to get an accurate weather forecast........impossible!!!!
  1. Can you replace a 885 LUX BCM with a 795 Hi?
    By hsv91ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2009, 11:20 PM
  2. How do I replace the fan
    By Radarboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2009, 09:02 PM
  3. How do I replace the AC fan? VS
    By Siggers86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2009, 02:28 PM
  4. how to replace bodykits
    By 94vrexec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2006, 11:03 AM
  5. replace the engine?
    By norticus in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-10-2005, 06:56 PM
