Results 1 to 11 of 11
Thread: Castor bush question
    VY SS 5.7
    Oct 2009
    Default Castor bush question
    Hi All
    Just had the castor bush changed on my 2003 vy ss....(at Holdens)....Noticed tonight that it looks like its leaking oil.....Does the joint contain oil or is it possible that its leaking from above...No leaks previous to the joing change
    Any ideas
    Thanks
    Alan
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    If anything it would be a bit of grease they put around there, unless you got some oil dripping on it from elsewhere.
    VY SII HBD Calais L67
    Dec 2006
    The genuine bushes are oil filled. Take it back to Holden for a look see. It's always best to replace these with a nolathane or superpro bush set as they last for years n years. The genuines will only last a year or 2
    VYII Calais L67
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Yep once the oil escapes it's time for a replacement. Urethane bushes provide a big improvement in steering/brake feel and last longer too.
    vy ss commodore 5.7ltr
    Jul 2006
    yeh i bought the genuines then got urethane's instead, still got the genuines in there packets at home if anyone wants them?
    VY SS 5.7
    Oct 2009
    Took the car to Holdens today and the new castor bush(replaced a couple of weeks ago) was faulty.It was leaking oil....They have replaced it and all seems to be ok..Thanks for all your help....How much are these new urethane replacements and are the worth the swop..Is there any advantage to changing them over?
    Thanks
    Alan
    Dec 2006
    My local does Superpro supplied and fitted for $240. You will most likely need an allignment after a week or so when the bushes settle.
    VYII Calais L67
    VS Executive Series 2
    Aug 2009
    Does anyone jonw of a good online supplier if these urethane bushes? if not where would be my best bet to get them from? how muhc would I be looking at?
    Hot House VY SS
    Jan 2010
    GSL Rallysport can do them, they are a forum sponsor and have a section at the top of the forum
    Dec 2006
    Jul 2006
    peddars, got mine through peddars and there not that expensive.
  1. Spigot Bush Question
    By Chris E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2012, 07:07 AM
  2. FS: Heavy Duty Urethane Castor Rod Bush Kit
    By RebelSS in forum Parts And Other Items For Sale
    Last Post: 22-02-2008, 06:55 PM
  3. Help asap with castor rod bush
    By hsv14u in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-06-2006, 01:35 PM
  4. Castor?
    By damianison in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-05-2006, 12:16 AM
  5. Clutch pedal bush question
    By Russell Coight in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2005, 09:27 PM
