I have a 25th Anniversary model (Executive base) and I've noticed my drivers seat is a fair bit higher than the passengers seat and my head is just below the roof. The electric adjuster seems to only want to tilt the base of the seat. Does anyone know how to lower the seat base so that it is level with the passengers seat?
so with the electric you've pushed down both ends of the button you can tilt the back and the front of the seat?
I'll give it a try tonight I had a quick look and that appeared to only tilt it and after a few minutes it is still just as high. Higher spec models have 2 buttons one is for height adjustment.
It's called the four way power seat, because it raises and lowers the whole seat, and tilts the front and rear separately. If you push the whole button down instead of just one end, the seat should lower. If both motors are working, there is no reason why it shouldn't work properly for you.
Thanks it worked. I pushed the whole button down but the seat goes back as well as down. I was able to then push the front of the button down to level the seat back up.
not a big fan of the electric seats. easier with the old style.
