Hi, I have a VY Equipe 2003 6 cyl and want to fit a VY Calais 6 cyl instrument cluster as the equipe is boring and plane. Q. Can this be done? Your help would be appreciated. Cheers ... Mike ... Grafton NSW.
Yes is can, u just need to get the calais cluster reprogrammed.
The Blue One
Also you need to make sure the cluster is from a VY - the VZ unit (blue plug) will not work.
and 3 Dangerous non ABS VN's
^^^Knew i forgot something![]()
The Blue One
It needs to be from the same series because your fuel gauge will work in reverse on the VY, i think the VY series 2 and the VZ are the same but im not sure
The Blue One
u will need the side airbags (srs) disabled on the cluster.
if you are in syd, talk to Greg (phreddy), he can do this, and i believe make a s2 fuel gauge go in reverse? but dont quote me on that
Thanks for all you help guys ... Mike!
I had the hsv dash put into my v6 base model ute. HSV had to program it as holden wouldn't touch it.
even with the base model single airbag body control module, they got it to work perfect.
they calibrated the fuel tank size, engine revs etc. and made it work with only 1 airbag.
It must be the same series as your car. otherwise fuel gauge will be reversed.
Check out my build <---Click me
Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
