Results 1 to 7 of 7
Thread: Bent Front Axle. what kinda of $$$ ?
    Harrison's Avatar
    Harrison is offline Donating Member
    04' VYII 3.8L A4
    Sep 2009
    Mount Isa
    Default Bent Front Axle. what kinda of $$$ ?
    Just noticed lately that my wheel scrubs when i turn into a full lock, then i also noticed my car drags to the side alot, and under heavy braking there is another scrubbing noise, so i had a look at the wheels thismorning and noticed there is probably an inch or two of gap difference with the wheels, (the right is closer to the body)
    just wondering if this is going to be expensive or somewhere cheap i can get it repaired around the sunshine coast area, QLD.
    thankyou
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Mate, how long have you had the car and have you hit any gutters or other hard objects lately? it's not likely to be a bent axle, but something amiss with the suspension and possibly, the subframe. Sounds like it's had a hit at some time. Get it to a wheel aligner and see what's out of whack and whether it can simply be re-aligned by adjustment. If damage is present, it will show up during the alignment process.
    Wheel alignment costs vary but around $60-$70 is a reasonable price.
    VY SII HBD Calais L67
    Dec 2006
    It will be the castor rod bushes. they are common on commodores and should be replaced with urethane ones. Nolathane, Superpro, Noltec are all more than adequate for the job. You will need an allignment after fitting most likely
    VYII Calais L67
    Harrison's Avatar
    04' VYII 3.8L A4
    Sep 2009
    Mount Isa
    yeah i have also been told my bushes need replacing but i did hit a gutter pretty hard the other night it was raining and i didnt know the roads too well.. learnt my lesson...
    if it is the axle, does anyone know the costs?
    03 VY V6 S2
    Oct 2005
    there is no axle in the front. theres a control arm, which has a hub/wheel at one end. Its attached to a shock absorber/spring which holds it up vertically and theres a radius rod which stops the wheel moving horizontally ie backwards.
    Harrison's Avatar
    04' VYII 3.8L A4
    Sep 2009
    Mount Isa
    Quote Originally Posted by unregistered View Post
    ahh excellent that helps me a little bit more now when i get quotes, got a rough idea on whether it can be bent or would you say its just the bushes? if so what kind of mechanic can fix a bent/broken/non bush problem?
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Quote Originally Posted by Harrison View Post
    If you've belted the kerb, there is a very good chance you have bent something and it won't just be the bushes.
    Any competent mechanic can replace the front end parts on a Commy - the suspension is pretty basic and very well known in the trade. No major need for special tools, unless you have bent the chassis. A wheel alignment after repairs have been carried out is essential.
  1. Possible Bent Axle ?
    By ragrim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2009, 10:28 PM
  2. what kinda car???
    By william002 in forum General
    Last Post: 13-06-2009, 07:38 PM
  3. [QLD] Front and Rear King Spring Lows live axle
    By holden-4-life in forum Parts And Other Items For Sale
    Last Post: 02-05-2009, 06:27 PM
  4. Bugger, my front Subframe is bent...
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2007, 06:29 AM
Tags for this Thread
