Results 1 to 12 of 12
Thread: timing belts etc
    vy2003
    Dec 2009
    Default timing belts etc
    Hi, I'm not car minded so plese excuse me if I ask any silly questions. I own a 2003 berlina and am trying to work out weather I should keep it for another 6-12 months or get a new one. So after just having to pay for a new timing belt kit in my husbands ute, i'm wondering when the timing belt etc need to be changed in the Vy's??
    Also it's done 157,000kms but in excellent condition fully serviced etc what else that isn't in a normal service would need replacing?
    Thank's in advance
    vy2003
    Dec 2009
    my baby
    May 2009
    HoldrodeoLT's Avatar
    HoldrodeoLT is offline I have no lemon pledge...
    2004 Holden Rodeo RA LT, 2008 Polaris Hawkeye 300
    Aug 2008
    VY's do not have a timing belt.. they run off a chain.
    And i dont think i have ever heard of a chain needed replacing
    unless it had some thing wrong with it.
    About as handy as tits on a bull
    vy2003
    Dec 2009
    VY Berlina Series 2 5.7l
    Oct 2009
    They have a serpentine belt that runs the aircon, power steering, water pump etc. There pretty cheap around $40 if u get it changed get the pulleys changed at the same time.
    VY SII HBD Calais L67
    Dec 2006
    Around 150000kms you may be up for engine/ tranny mounts and strut top bushes along with castor rod bushes. These are all very very common on commodores.
    If you were to get them all done at once (assuming they need doing at all) it would only set you back $850-$1000. I would recommend against using genuine bushes except for the engine mounts. Nolathane or similar are longer lasting and better performing if you were to keep the car.
    VYII Calais L67
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    if your husband needed new timing gears/ belt, I'd be telling him to stop flogging the ****en car while it is cold.
    as the boys said. serpentine belt, they crack. if they go, no water pump, no power steering, no aircon, no electrics.
    timing chains can wear and get loose but you will hear a very audible noise, before they need replacing.
    most probably wear on a commy is as chargedvx6 said, bushes and mounts. you also want to get your universal joints replaced, diff oil changed, and new flange gaskets on you next service
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    Dec 2009
    YV's dont have universal joints they have rubber doughnuts. Centre joint is not servicable DIY in a VY according to Spicer web site. Diff oil does not need to be replaced unless the car tows heavy loads like a caravan, level just needs to be checked. What should be replaced is the brake fluid and power steering fluid, engine coolant and if no history on auto have it serviced.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Quote Originally Posted by wortus View Post
    'YV's' !!!!!!
    VY V8 Berlina
    Nov 2009
    Any way to tell if these drive belts are wearing out or loose or need replacing?
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    Quote Originally Posted by mars6484 View Post
    you will notice craking in the belt when it needs replacing. However i have seen them left on and not brake for thousands of kays after noticing the cracks.
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
  1. belts slipping
    By dijm8 in forum LSx Development and Modification
    Last Post: 07-10-2011, 12:03 AM
  2. door belts help
    By red_vb in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-09-2009, 12:36 PM
  3. Timing belt to Timing gear's ?????
    By MMH84D in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2009, 11:28 PM
  4. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  5. Seat Belts
    By jamiekratin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-09-2005, 11:00 PM
