Results 1 to 5 of 5
Thread: T/C button stuck!
    VY V8 Berlina
    Nov 2009
    Default T/C button stuck!
    Hey guyz
    my cars previous owner I'd say spilt some drnik around the gear stick where the T/C button is and it is sticking and very hard to pull back out once pressed. Sometimes it also turns on and off by itself as the button is having difficulty operating smoothly.
    Just wondering if anyone had an easy way to fix this, like pouring a little bit of some substance that would dissolve the drink making the button stick a bit? or something?
    I really don't want to go to the hassle of pullin apart the centre console and cleaning it manually if possible, or if this is really easy if someone can give me tips on that, would also be great!
    Thanks!
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    HoldrodeoLT's Avatar
    HoldrodeoLT is offline I have no lemon pledge...
    2004 Holden Rodeo RA LT, 2008 Polaris Hawkeye 300
    Aug 2008
    I have a feeling pouring more liquid into the button will only make things worse...
    Better put you dash puller aparter hat on!
    About as handy as tits on a bull
    Harrison's Avatar
    Harrison is offline Donating Member
    04' VYII 3.8L A4
    Sep 2009
    Mount Isa
    Quote Originally Posted by alien View Post
    Really easy to remove the console:
    How to: Remove Dash and Center Console VY-VZ
    Probably also going to be the best way for fixing it :P
    yes it is the easiest way to do it... i pulled mine out very simply... just need to hold your tongue right..
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Liquid (water etc) and electrical components don't go together. You are likely to short everything on the curcuit. Bad news. Expensive too !!
  1. Vs a/c button stuck in 'on' position
    By donf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2009, 06:42 PM
  2. A/C on/off button stuck in on position
    Last Post: 21-04-2009, 10:48 PM
  3. WTB: VS speaker pods, Air con button, demister button
    By TA 91 WA in forum Swap / Wanted to Buy / Trade
    Last Post: 14-08-2008, 11:17 PM
  4. cassette button stuck in
    By kaycee in forum Car Audio
    Last Post: 28-12-2005, 01:10 PM
  5. Stuck?????
    By liquidforce_134 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2004, 07:48 PM
