Results 1 to 7 of 7
Thread: VY repeated battery drain
    Vp Formula
    Mar 2006
    Default VY repeated battery drain
    Hi all,
    I own a VY v6 exec that for the last week has been draining batteries overnight.
    I have tried and tested 3 batteries and all are ok, the alt is charging at 14.4 v and isnt grounding out.
    Has anyone had any problems with circuits causing a draw? I have already removed interior lights and everything is standard. I'm thinking maybe security system??
    Any help would be great as the missus is planning on driving 12 hours up the coast in the morning and doesn't really wanna be jumping it for the next couple of weeks...
    Cheers guys
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    Vp Formula
    Mar 2006
    VY II "S" ute :)
    Dec 2009
    NSW West Sydney
    shouldnt be your lights mate, these cars are equipped with a power saver so if you leave the interior light on, or glove box open they will only stay on for 1 hr after the car is locked.
    id be looking into the alarm system, does it happen when you dont use the alarm?
    also check your earth lead from the battery, make shore its connected securily
    VY Executive Commodore
    Jun 2010
    You probably have sorted this issue by now, but I just had the same issue where the battery would drain over-night. I found connecting an amp meter would show a 10 amp draw then drops down to a couple of milli amps then back upto 10 amps again and so on.... Try listening under the drivers seat for a faint clicking sound every 10 seconds. If you do hear the click sound then it is one of the adjustment seat motors jammed! A temporary fix is too remove the power seats fuse ( 20 amps) located under the steering wheel console (will have to remove bottom cover - pull towards you at the base, it is clipped in) - you wont be able to adjust your seat up and down but at least it gets you going again
    Last edited by VYTony; 12-06-2010 at 02:45 PM. Reason: informed location of power seat fuse
    KBone's Avatar
    KBone is offline Shaunoff
    VY SS
    Oct 2005
    If you have an after market sterio, check the wiring is connected properley.
    VY Commodore Ute
    Dec 2009
    North Adelaide,SA (uni) / Mildura, VIC (home)
    I had the same problem, Alternator regulator (think its called that) was dodgy, even thought it was a brand new alternator i had.
    So the alternator was remaining actuated 24/7 draining the battery overnight.
    Bought a new regulator (50$ ripoff! whole alternator was 70$!) and its a simply screw on/off thing, easy to do.
    Also the alternator even with the car off, was making a very very slight electronic humming.
    When i say slight, i mean so quit a few ppl i had helping me find the solve the problem could not hear it. and an auto elec did not hear it.
    Not all regulators might hum when broken, but mine did.
    PS: Regulator is the black plastic box on your alternator, there's only about 3 parts to the alternator and its one of them so not to hard to find.
  1. Drain on Battery when car off???
    By mattman in forum Electrical Wiring / Questions
    Last Post: 03-01-2010, 08:35 PM
  2. VR Battery drain
    By metlhead666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2009, 04:57 PM
  3. Battery drain
    By Philthy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-09-2008, 02:58 PM
  4. battery drain
    By fitzy2005 in forum Electrical Wiring / Questions
    Last Post: 13-05-2006, 08:53 AM
  5. battery drain
    By shamden22 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-04-2006, 07:37 PM
