hey guys my vy series 2 wont start, the electronic ignition keeps playing up i have replaced the crank angle sencor does anyone else know what the problem might be with no spark coming from the ignition
ummm without any details of how it won't start all I know is if the ignition switch is okay, then maybe the battery or starter motor?
Is the battery in your key going flat. take it to a key cutter and get a new one. if it goes flat then you can only get a replacement from Holden. The first signs of a key going flat is the car not starting first time and it can sound like a flat car battery, in that the car has trouble starting.
the key maybe flat it has been play silly buggers a bit, but the car is trying to turn over but there is no spark coming from the plugs
is the security light turning off when you are trying to start it?
heres my ride, i know its not much but its mine
http://forums.justcommodores.com.au/...-ss-crewy.html
and heres my new project
http://forums.justcommodores.com.au/...ml#post1104629
