Results 1 to 6 of 6
Thread: high pitched wine vy manual
    VY II "S" ute :)
    Dec 2009
    NSW West Sydney
    Default high pitched wine vy manual
    Hey guys i have recently brought this vy ute manual, and its got this high pitched wine.
    it comes on after about 2500rpm, and get louder with more revs.
    It goes away when you take the slack out of the clutch pedal, no pressure on the pedal just taking to slack (2-5mm)
    I am thinking its either spiggot bush, or thrust bearing. anyone had something similar??
    I also wanting to know will it cause any damage? as to do either its a fairly time consuming job and would be worth getting the whole clutch assy done, cars got 145000klms and on its first clutch. So soon the clutch will need doing and i was going to wait untill then.
    also its not all the time, sometimes its worse then others and sometimes not really evident lolz
    thanks guys
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    Open the passenger side door and kick the bitch out!
    Seriously though.... I've got no idea.
    VZ SS Thunder 6L
    Jul 2008
    Castle hill
    I don't suppose that whining noise is coming from the speakers is it? :P
    just a thought
    Check out my ride!
    VY II "S" ute :)
    Dec 2009
    NSW West Sydney
    tried kicking the bitch out, lolz not her.
    also its not coming from the speakers, u can only hear it with the radio off its that subtle. Also it something involved with the clutch cause it only happens when theres no pressure on the pedal
    cheers for the thoughts anywho :P
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    Could be either the spigot or the thrust bearing. Generally they make different noises so a good mechanic should be able to tell the difference. I hafound that spigot bearing noises get louder when letting the clutch out and thrust bearing noises will go away when you have that light pressure on them, so my guess is thrust bearing.
    If you are going to do a clutch anyway i would change the spigot as well just to make sure you dont have to pull the box out again.
    Cheers Shane
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
    VY II "S" ute :)
    Dec 2009
    NSW West Sydney
    cheers for that bud, i was thinking it was either of the two.
    do you reckon it will be ok if i fix it all (including spiggot bush) when the clutch is seeing its day?
    i just dont want to to cause more damage, which i can see it doing really but rather be safe then sorry
    cheers mate
  1. high pitched squealing
    By ruggj in forum Car Audio
    Last Post: 10-11-2009, 09:56 PM
  2. High pitched noise
    By nick3110 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-07-2009, 04:55 PM
  3. High Pitched Squeal
    Last Post: 15-12-2008, 11:05 PM
  4. high pitched squeal
    By 5ivespeed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2008, 08:39 PM
  5. Stange high pitched sound
    By VLishes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2006, 08:45 PM
