Results 1 to 17 of 17
Thread: Head light switch
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Default Head light switch
    Does anyone know if the vy series2 headlight switch is illuminated? Everything else is but not this switch. Also what is the white plug with the 5 or so prongs to the left of the glove box? It's easy to see if you take off the panel that supplies air to the door vent, you know the panel that has the "no baby capsule" emblem due to the air bag.
    SuperSixty6's Avatar
    SuperSixty6 is offline Alto Rullo
    Landcruiser TD
    Dec 2008
    Brisbane.
    My VY Sr 2 Berlina one is Illuminated, And i am quite sure that my Sr 1 VY Executive is also illuminated.
    I assume your bulb is probably gone? Common problem with incandescent lamps.
    Cheers,
    Super6
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Ok I have gently pried at the switch with a small flat head screwdriver and it doesn't want to come out, what's the trick please?
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Any one? How does the head light switch come out, would like to check it today and replace bulb if needs be. And still wondering what that plug on the passenger side is^^^^? Thanks guys.
    VY2 Berlina
    Jun 2008
    Castle Hill
    VY s m5 supercharged
    Aug 2008
    No dont pull it
    take off the cover plate on the dash where the air passes from the dash to the door and then take the cluster sourrond off, reach in and there are 2 small clips you must press in on each side to be able to remove the swtich
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Thanks, I got it off -by pulling it! all good, but couldn't get right in to the guts of it to check for a light. Still waiting to hear if anyone knows what the plug on pass side is for?
    Aug 2008
    Quote Originally Posted by VYMAD View Post
    There are 4 or 5 led's in there even if you got it open there is not much that will tell you if they are working as ther are not a normal globe.
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by 0081 View Post
    Ok thank you, I'll just live with no illuminated headlight switch.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    My head lights are on all the time anyway, i like to cause you stand out more and people have a harder time saying, i did not see you. why do you always see bikes with headlights on, cause you have no choice they are always on. so i never use the switch now lol
    Aug 2008
    The lights are not LED's they are globes, i got them confused in my last post
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    how do you open the headlight switch. I have the back cover off, and I can see the shaft but now I'm stuck.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by sp001in View Post
    That's as far as I got too, doesn't seem to want to come apart.
    Aug 2008
    Once you have the back cover off i used a flat blade screw driver to pop out the shaft, the black nobby thing in the center.
    Then remove the 2 silver clips that hold it into the dashand then pcb will come out.
    Take note which part goes where and which way or you will be stumped for a while (i was ) some parts only go in one way.
    to put it back together non fog light switch
    1 pop the shaft into the back housing (must go in the way it came out it the switch will not fit back together, it appears to fit bothways but it will sit further in one way, thats what you need)
    2 place the pcb on the shaft
    3 put on the little part that turns and makes the connections (what ever its called, will also only fit one way)
    4 push on the clips that hold the switch to the dash
    5 insert the base with all the above parts into the other half of the switch untill it clips in
    6 push on the part you turn for the lights to come on
    for the fog light switch there is a extra part between the shaft the rear part of the pcb.
    The switch will come apart more but its a real pain to get back together and you dont need to take it out to get to the globes.
    If you need ill take a pic tomorow.
  15. #15
    Aug 2008
    Just so you know the only difference between the fog light and non fog light is a connector that moves and a plastic part inside.
    The pcb is the same
  16. #16
    VY S L67
    Nov 2007
    on vy 1 i think car needs to be on and the headlights on.
    on vy 2 only car needs to be in ign.
    they all work. mine never did, the one day 1 of the 5 globes worked. get phreddy to hook up a fix in green if you want.
  17. #17
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by taztassio View Post
    Hey I checked and you're right, there's nothing wrong with them, the ignition just needed to be on!
LinkBacks (?)
  1. VP Head Light Switch
    By Gillsy699 in forum Electrical Wiring / Questions
    Last Post: 08-10-2009, 04:19 PM
  2. How to remove head light switch from dash surround please
    By smokin_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2009, 05:05 PM
  3. VY Head light switch
    By Flat_White in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-10-2008, 08:40 PM
  4. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  5. Removing aircon controls, mode switch, light switch
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 10:53 AM
