Originally Posted by
jet-6
What you need to do is look at it from the inside, you need to remove the steel part from the plastic suround 1st, if you dont you WILL bust the plastics
Inside are two tiny little locking tabs, you need to push them in while pulling the metal part out, once you have done that you will be able to pull it out
You might have to undo the cable/plug from the rear 1st, just two screws, one either side of the rear of the console and the whole back air vent assembly comes out, you can then see in there sort of
