Results 1 to 7 of 7
Thread: Radiator Hose Clamps
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Default Radiator Hose Clamps
    Those spring type hose clamps(the "crimp style" clamp) GM and others are using for coolant hoses are a pain and much more difficult to release and move than the traditional screw type band clip that is still used on some of the coolant hose connections.
    The use of the crimp type clamp on the bottom radiator hose is especially difficult and I have replaced mine with a traditional screw type clamp so next time it will be easy to remove when I do another coolant flush job. I will do the same on the top hose next time I need to remove it although these are a bit easier to deal with. I found the only way to remove these crimp clamps without the proper crimp tool is to use adjustable multigrips with a wide mouth.
    I know it is possible to over tighten the screw type clamps, and to strip them, but I have never had a new one of these fail on any vehicle or to pierce the hose rubber due to over tightening. I assume GM likes to use the crimp style clamps where possible because they are much faster to install on the production line.
    Just wondering what are other people are doing with these.
    Dec 2009
    I dont have any trouble with them. I recently flushed my radiator as well. I found them easy to remove and replace the bottom hose clamp with multigrips. I noticed that on older VT's for example the top hose is the same where as on my VY and other VY's I have seen it is a jubliee type clamp.
    I'd steer away from using jubilee type clamps on the heater tap just incase you overtighten them and crack the plastic.
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    all my standard clips started to leak. so ive replaced them with the screw in type. no more leaks
    dylanstone's Avatar
    dylanstone is offline tsu tsu tsu tsu
    3.8L 1997 VT executive
    Feb 2010
    sydney, eastern suburbs
    thread dig i know, how do i get these retarded clips off? im flushing it on sunday and wondering if i need anything special?
    cheers
    * 1997 VT executive
    * 2.5 inch Lukey catback
    * Lowered on Munro shocks Pedders springs
    * Fusion 1000 watt amp & Kenwood 12 inch sub & head unit
    VY S Series 2
    May 2010
    if your talking about the spring clips just get a set of multigrips and you should be fine
    i would look at replacing them with the screw type ones cause with the heat and all the spring clips usually start losing their grip after a while
    dylanstone's Avatar
    Feb 2010
    alright cheers, i can get a multi grip from supercheap right? ---- how much do they cost?
    * 1997 VT executive
    VY S Series 2
    May 2010
    yeah supercheap, auto-one, bunnings pretty much any tool place will have them
    should only cost ya $15 depends on how much you wanna spend really
    no point spending big cause youll only be paying for the brand and its not like youll be flogging them
  1. reusing original hose clamps
    By commsirac in forum General
    Last Post: 14-04-2009, 02:00 PM
  2. tighten those fuel hose clamps
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-12-2006, 09:26 AM
  3. Radiator Hose Clamps..
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2005, 08:29 AM
  4. Spring Steel Radiator Clamps...
    Last Post: 05-12-2005, 05:38 PM
  5. radiator hose
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2005, 08:01 PM
