Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: Will a VY SS Exhaust Fit A V6?
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Default Will a VY SS Exhaust Fit A V6?
    Hey all, i am hoping to buy a VY soon after selling my vs today.
    I see alot of ss exhausts come up for sale and i'm wondering if you got a new Y pipe or pipes from the headers to cats made up, could you bolt up an ss exhaust?
    Thanks.
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Dec 2008
    Ah thats annoying.
    but still, as a theoretical thing it should follow the same path shouldnt it?
    If you had pipes to line up the v6 headers >>> ss cats or to ss pipes it should?
    Dec 2008
    06 VZ Executive
    May 2008
    Sunny Coast Qld
    I have a VZ exec and have fitted a VY Clubman cat back exhaust. Simple bolt up fit, but you need to fabricate a mount for the right hand side mufflerand get it welded to the subframe as per the left hand side. Everything else was the same. Same spacing on the flanges.
    Dec 2008
    06 VZ Executive
    May 2008
    Sunny Coast Qld
    Smile
    Better than standard. Not too loud, doesn't attract the wrong type of attention. Unfortunately it doesn't seem to have improved economy or performance. I like it, plus it was only $15 on flea-bay! Gotta get lucky sometimes!
    VZ SS Thunder 6L
    Jul 2008
    Castle hill
    I had the cat from the VY SS exhaust welded onto my standard exhaust, sounds pretty good. Adds a touch of performance, but i've had a few compliments about it. But mostly it was cheap as chips.. Cost me $200
    Check out my ride!
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    The SS Exhaust will ONLY bolt straight on a VY Supercharged V6 engined car. As the Supercharged donk has identical twin cats twin system right back to the rear muffler. The ONLY difference is the SS exhaust chrome tips hang out about 50mm too far beyond the rear bumper bar line , as the rear bar on a normal VY hasnt got the bottom skirt on it that the SS bumper has. Easily fixed by cutting 50 mm off the rear pipes & rewelding the chrome tips back on. I have put a SS system on my SuperV6 VY Calais & its a ripper , far better note & notable performance gains. But it wouldnt be worth trying to fit to a non super V6 (too much mucking around)
    06 VZ Executive
    May 2008
    Sunny Coast Qld
    Quote Originally Posted by colgf View Post
    I beg to differ on a few points. As mentioned earlier, I have fitted a cat back system from a VY Clubbie to my stock standard VZ 175kw exec, so I know that the outlets from the VY Clubman cats are exactly the same spacing and position between these two models. It only stands to reason that the SS and VY V6 should have the same spacing too. Please correct me if you know that I am mistaken.
    Sep 2007
    You are talking VZ , which does have a twin system right thru , but VY has a single system, unless its the supercharged donk......
    Dec 2008
    Thanks for the help here guys, i saw so many standard ss exhausts kicking around for cheap but not sure if its worth it or not..
    Cheers.
    one_and_only2004's Avatar
    one_and_only2004 is online now Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Most post 2003 series 2 vy's have twin cats - supercharged or not.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    06 VZ Executive
    May 2008
    Sunny Coast Qld
    Standard VZ 175kw execs have a SINGLE system, twin cats yes, but a "Y" piece joining the 2 sides into a single mid-resonator and single rear muffler.
  15. #15
    VY II V6
    Dec 2006
    Any factory or aftermarket twin exhaust designed to bolt up to a ls1 or L67 will not bolt up to ANY VY n/a ecotec. Been there, done that. If you're adamant on using the twin system then youll need to buy extractors from HM headers and cats from a VY series 1 HSV. That's the simplest way of getting those twin flanges without having to weld up anything.
  16. #16
    VY S L67
    Nov 2007
    Quote Originally Posted by nick_ View Post
    vy 2 v6 it will bolt up to mate.
  17. #17
    carless for now
    Feb 2007
    perth,Western Australia
    i dont understand why you would even want one the stock systems are shit fot the ls1 thats why there so many for sale and are very restrictive dunno if there good on a stock ecotec or l67 though
  18. #18
    VY II V6
    Dec 2006
    Quote Originally Posted by taztassio View Post
    No f***ing way champ. Otherwise I would've done that. I'll show ya next time I see ya on msn..
  19. #19
    Mar 2008
    Quote Originally Posted by Vt_vic View Post
    I suppose they're quite restrictive when you're pumping 240KW out at the wheels, but how about when you're only pushing 150KW at the motor?
  20. #20
    VY s m5 supercharged
    Aug 2008
    The series one has one cat so it wont but the series 2 has 2 cats and it should.
    I dont know about the super6 tho
  21. #21
    VY S L67
    Nov 2007
    you have gas? different cats maybe
  22. #22
    VY II "S" ute :)
    Dec 2009
    NSW West Sydney
    my vy series 2 ecotec 2004 ute has twin cats.
    the series 1 has 1 cat and series 2 has 2 cats as far as i know.
    hence why on ebay listings for vy 6cyl exhausts they say "WILL NOT FIT SERIES 2"
  23. #23
    Mar 2008
    Meanwhile my FREAK of a series 2 has only one cat. I lucked out there for sure....
  24. #24
    Dec 2009
    Not all series 2 VY's V6's have twin cats. This was a mod that came out early in 2004 to comply with an updated exhaust emission law, I've had a look at a friends car that has this setup and it also has the revised power steering pressure hose. My VY is a series 2 V6 build in October 2003 and it has a single cat.
  25. #25
    VY II "S" ute :)
    Dec 2009
    NSW West Sydney
    well then lolz it gets more and more confusing.
    so what exhaust will fit a series 2 twin cat?
  1. [VIC] HSV R8 exhaust system -suits all Twin Exhaust VE Sedans
    By vol800 in forum Parts And Other Items For Sale
    Last Post: 13-01-2010, 05:37 PM
  2. [SA] Swap VY custom exhaust for standard vy exhaust
    By SAV_117 in forum Swap / Wanted to Buy / Trade
    Last Post: 09-09-2009, 09:20 PM
  3. Exhaust / Catalytic flanges, Exhaust swapping
    By social in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2009, 11:02 AM
  4. Wanted VS V8 exhaust / HSV exhaust / Merge pipe
    By prettyboringbloke in forum Swap / Wanted to Buy / Trade
    Last Post: 21-02-2008, 03:06 PM
