hi
i own a vy 03 with a s wing on it and i want to remove it dose anyone know if this can be down easily and do i have to put a brake like in my back window now that the one on the wing is gone and dose any one know were i can get the plugs that go in the holes that it will leave once i remove it thanks
Look up dvsv8s ride page he done it ,but got it filled and repainted
I cant say i know how to remove the rear spoiler/wing, but i always notice holes in the bootlid of people who have removed theres, so maybe there are screws or something like that on the underside. As for the brake light, i believe that you WILL have to put a brake light in your rear windscreen like every other car.
i did it on my vz and i assume its the same.. just pop the boot, and u can see 2 bolts on each side.. un screw them, and there is a clip on the inside on the boot lid, u can get to it pretty easily and unclip the brake light, and lift it off, simple as pie.. takes like 5 mins![]()
You will have to replace you back rear windscreen if you wish to use a holden VY light as were the light would of been is blacked out. You can get a new led light and stick it up the top of the window and it would be cheaper.
