Results 1 to 13 of 13
Thread: Petrol Smell on car after leaving it for a while...
    Mercedes C200K AMG-Sports
    Mar 2007
    Question Petrol Smell on car after leaving it for a while...
    I've been filling up with petrol for the last weeks now and no problem. Saturday I went to fill up the good old 98 Ron Vortex (I usually try to fill up 98 if its available). Since then when the car is off and I come back after an 30 mins or so I can smell petrol in the cabin. If I am in the garage I can smell it there outside the car. Even when I get into the car from leaving it overnight. But this disperses quickly when I start to drive. If I get out after a drive no smell at all. If I stay in the cabin for 3-5 minutes after the engine is off still no smell.
    The car has LPG but due to a problem I've been driving it on Petrol for a few weeks with no problems smell problems except the last time I filled up.
    I'm thinking it may be a bad batch of fuel but not sure? This morning, with just over half a tank left, no smell.
    Aay ideas?
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Read about this same problem in another thread on this site recently.
    Apparently the cause in that case was either a faulty fuel cap or failure to fully lock on the fuel cap due to insufficient turns.
    Mar 2007
    Quote Originally Posted by Sean880 View Post
    I might check the fuel cap... funny if it was as easy as that
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    idno if this helps but due to the warmer days the preasure builds up in the tank. my mate was sayin in his vx he has a fuel smell in the cabin when the air con was on, so i told him to loosen his fuel cap. the moment he did that there was a small hissing like air escaping. he then tightened it back up and it was fine.
    Mar 2007
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Funny enough mate i have the same problem, only happens when i put petrol in though, after a day or so it will go away. You cant smell it while your driving only when your pulled up.
    Mar 2007
    Well, no 'hissss' when I pulled the cap off but it may have been a little loose... had about half a tank but no more smell...
    VY Storm Ute
    May 2009
    If you spilt some fuel and the hole and tube that is meant to drain it away is blocked this will cause a smell.
    Try slowing pouring water around the area (leave your fuel cap on!) and see if it is draining correctly.
    VYII Berlina 3.8, VE Calais V 6L
    Aug 2005
    Weird mate. Iv'e been noticing since we started summer that no matter how full my tank is, if I leave it idling with the air con on for 15 mins or longer, it starts to smell like petrol outside and inside the cabin, then disappears after I start driving off. My car is not duel fuel and the smell is never there when the car is sitting turned off.
    Mar 2007
    It came back again on a really hot day. I filled up today and I noticed fuel stains around the cap. I cleaned them. Lets see how she goes.
    2003 VY CV8 Monaro
    Jan 2010
    I just had the same issue. I have a VT as well, swap over the caps and problem solved. I noticed that after 15 minutes of driving the cap was coming lose. Might need a replacement cap.
    VY, S supercharged 2003
    Dec 2006
    This has to do with Holden routing the fuel tank breather after the charcoal cannister back into the cabin.
    Yeah, tell me about it - very bright idea whoever thought of it at Holden.
    I faced the same issue in my VY and found out about it then. My GF nearly choked coz I left her in the car for 3 hours in hot sun with AC on and the fuel smell. He he. There is a thread on this, search if you are really keen.
    Just ignore it and keep windows open when sitting idle in hot weather. There's nothing wrong with your car.
    Mar 2007
    Well, I just wanted to report that after that 'smelly' tank was empty, I filled up with 91 RON (patrol station was out of 95 & 98 RON). Guess what? Smell was not there. So could it have been that this particular batch of 98 RON I used was bad?
    My LPG system is fixed now [under warranty] and I wont be doing as much petrol driving as I did in the last months anyways.
  1. petrol smell on a hot day, why?
    By admir87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2009, 11:43 AM
  2. petrol smell
    By thinedge in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 12:26 PM
  3. petrol smell
    By markandsam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2009, 05:40 PM
  4. petrol smell
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-10-2008, 12:12 AM
  5. petrol smell
    By bboystyles in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2008, 12:07 PM
