Results 1 to 20 of 20
Thread: VY Series 2 V6 Rattle at mid-high rpm
    VY Executive Series II
    Nov 2008
    Perth, Western Australia
    Exclamation VY Series 2 V6 Rattle at mid-high rpm
    Gday all,
    Just driving around today around on the freeway, ect and i thought i'd put the boot in at a set of lights, only to hear this unearthly rattle/vibration coming from the mid/mid right section under the hood. Since then i have noticed the sound whenever the car pulls past about 3000rpm. Never heard this sound, and i can assure you its not the first time i've givin it stick at a set of lights.
    Help would be appreciated, got a cruise down to Mandurah for Australia Day, and would hate for my engine to fall out lol.
    Thanks in Advance
    Cam
    P.S Could it be my cats have finally died (they do rattle a bit on idle), and i probably should replace them
    one_and_only2004's Avatar
    one_and_only2004 is online now Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    I have the same problem - i pulled off my exhaust and the cat is a performance straight through design, the whole guts of it have come loose and are slowly rattling out! . Does it creak and rattle at just under idle revs?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Nov 2008
    Yeah they do, although its intermittent at times, Since series 2 VY's are dual cats though ill have to replace both, mite get outside in a bit and belt them with a mallet, see if it changes the vibration at all
    Mar 2008
    just unbolt your exhaust and poke the honeycomb bit with a screw driver. Mine is loose - i can push it around.
    Lucky i planned to go twin hi flow cat next month really...
    Nov 2008
    Wink
    Yeah will unbolt it first thing in the mornin *cough* going to gut them *cough* lol, should do for a temporary fix until i get around to buying some next week. Thanks for your help mate.
    Mar 2008
    No worries. Let us know if it stops the rattle.
    VY SII HBD Calais L67
    Dec 2006
    Quote Originally Posted by VYCamo View Post
    Gutting cats is a backwards move. It will reduce performance. Do it properly and get a wrecker replacement cat if ya can't afford a newbie ffs
    VYII Calais L67
    Mar 2008
    Quote Originally Posted by chargedvx6 View Post
    You obviously have no idea how annoying the noise is then.
    VY II V6
    Dec 2006
    I know first hand how annoying it is, but he is right. It is a backwards move and he'll be underneath the car again shortly after he's gutted them..
    -Nick.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    If you think the rattle is annoying, wait till you get the fine for gutting the cats. Fines worth more than your whole car is.
    Ronald Reagan (1986)
    Mar 2008
    It clearly states that he's buying new cats next week. SHEEEEEESH!
    VX Berlina
    Apr 2007
    Having them gutted for 1 day can land you a massive fine. Would it really be worth the risk? GEEEEEZ
    Mar 2008
    VX Berlina
    Apr 2007
    Is it worth the risk? Massive fine versus a few more days with a rattle. SIIIIIIIGH
  15. #15
    Delish-VY's Avatar
    Delish-VY is offline Steve
    2003 VY S pack
    Jan 2010
    Originally - Eastern Suburbs - Melbourne, Currently - Cairns
    lol one and only you"ve been watching a little too much napoleon dynamite
    My VY S-Pack
    Quote Originally Posted by wraith View Post
    Don't ruin a good story with facts.
    Pet Peeves - V6 Modded Exhausts - Rims on Front/Stockies on back - Chev Badges - Kitted cars with trolley strips - Fusion & it's fanboys
    Having less rights than a balinese prison
  16. #16
    VX Berlina
    Apr 2007
    Only watched it once and that was a while ago. So can't remember most of it. Anyway, VOTE FOR PEDRO.
  17. #17
    VYII Commodore S
    Mar 2010
    Dunno if mine is the same as op's, but I have a rattle in my VY2 S coming from the exhaust area (haven't noticed any rattles coming from under the hood, though) particularly at around about idle revs. It sounds a little bit like a loose screw.
    Assuming it is the same rattle, approximately how much would I be looking at spending to have it fixed? I had a similar rattle in my old car - which turned out to be a cracked manifold - and had to fork out $200-300 to fix it. I would probably be thinking about replacing/upgrading the muffler/exhaust (if that is the problem) if that isn't too much more expensive. If so, any tips? I wouldn't want it sounding like a 180 with chromes, just a bit louder.
    PS, despite studying mechanical engineering, I still only have a reasonably basic understanding of cars (mechanically speaking), so bear with me.
  18. #18
    04 VY S Pac Series II
    Apr 2006
    I had a mid front rattle, sounded like the exhast, turned out that one of the small heat shields had busted screws and would rattle at idle/low revs and woud dissapear at higher revs. A pair of tin snips soon fixed that!
  19. #19
    Harrison's Avatar
    Harrison is offline Donating Member
    04' VYII 3.8L A4
    Sep 2009
    Mount Isa
    for a while when i planted my foot i had a rattle that was driving me insane...
    had a play around under the hood one day and noticed that my engine cover had only 3 rubber grommets in it.. went to holden, got a free one and problem solved... im not sure if this is whats happening with you but it worked for me. its easy enough to pull your cover off and have a look.
    harrison
  20. #20
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Rattling noise from an Ecotec above 3000rpm? yes that's normal
  1. centre cap rattle? Series 2 Calais wheels
    By Darkk_Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-08-2009, 01:23 PM
  2. VP Series 1 Commodore (Idle is too high?/Overheating problem.)
    By icePiK in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2009, 05:28 PM
  3. high pitch squeeling at high speed
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2008, 09:29 PM
  4. Door Rattle - Yes the Rattle that hunts Holdens
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2006, 09:01 PM
  5. Selling blue high top console (Series 1)...
    By VL Soldier in forum Parts And Other Items For Sale
    Last Post: 17-05-2006, 01:30 PM
Tags for this Thread
