Results 1 to 4 of 4
Thread: Ecotech Plenum and Throttle Body Cleaning
    Dec 2009
    Default Ecotech Plenum and Throttle Body Cleaning
    When I got my VY about 15 months ago the throttle was a bit sticky off idle, cleaning the carbon out from around the butterfly on the throttle body fixed that. Yesterday I had a look at it and noticed there was carbon building up again so I cleaned it however just in the plenum there is a thicker wet black deposit building up.
    Questions are is this build up normal and does it eventually effect performance and fuel efficiency and can the plenum be cleaned on the car by removing the plenum top cover plate and is a new O ring required? I'll remove the throttle body next service and give it a good clean off the car, after you use throttle body cleaner is any lubricant required to lubricate the throttle body at all?
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    You'll find that behind the throttle butterfly (which will probably look spanky and clean now) there is a tons of gunk in the plenum itself. It wont' actually cause any problems unless it gets really bad (unlikely on a car which is relatively new like a VY), but if you want to clean it out it's easy enough to take the engine cover off, then the top of the plenum (there are 6 or 8 hex bolts around the edge, then it just lifts off if memory serves).
    Give it a good spray with carby cleaner and you should be good to go.
    If you want to go hardcore you can take the whole plenum off, if you do it's a bit more involved, but is a good opportunity to check your PCV valve and replace if needed.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    vt s s1
    Mar 2009
    Good write up there
  1. Larger throttle body/plenum spacer: worth it?
    By jhawk in forum V6 Development And Modification
    Last Post: 13-02-2010, 06:15 PM
  2. Cleaning Throttle by Removing Plenum Top
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-11-2007, 05:23 AM
  3. Ecotech / Throttle body
    By ecotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2006, 08:50 PM
  4. Cleaning the throttle body of an ecotech?
    By gogoboygareth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-09-2005, 03:42 PM
