Results 1 to 7 of 7
Thread: VY SS will start, then turn strait back off
    Jul 2006
    Default VY SS will start, then turn strait back off
    Hi guys.
    A mates VY SS has a funny issue, but it rarely happens, maybe about once a month.
    He will start his car, and it will start, but strait away it will turn strait back off. To get it to turn over again, you have to turn the key all the way to the off position (not just accessories) and then try again, where it will do the same thing. If you give it a bit of throttle once its started, it still stalls.
    This happens about 10-11 times before the car will stay started, and this issue will then not happen again until maybe a month or two down the track.
    Any ideas why??
    VN S1 (was VR) V6 Hilux
    Apr 2009
    Idle Air Control valve my need a clean, but it could be something else too.
    HoldrodeoLT's Avatar
    HoldrodeoLT is offline I have no lemon pledge...
    2004 Holden Rodeo RA LT, 2008 Polaris Hawkeye 300
    Aug 2008
    Sounds like fuel pumps on its way out..
    Does he get RPM surges?
    About as handy as tits on a bull
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    check your air intake. i had this problem in mine when i was installing a pod filter as the engine is registering more air coming in. when it starts does it rev a few times by itself then stalls? or if you chuck it in drive it will be in limp mode then shut off.
    also, try disconnecting your battery and reconnecting it to reset the computer
    HSV Clubsport VZ Body Conversion - Mace CAI - 2.5" Walker Single Catback - Red Neons - Custom Dash
    Jul 2006
    Thanks for the replies. I was thinking fuel pump, but no it doesnt rev surge. When it works, it works flawlessly.
    I will have a look at the instake and other things mentioned. The hard part is going to be knowing whether they fixed it or not as will have to wait a while for it to do it again.
    Cheers guys
    Aug 2008
    Quote Originally Posted by v6lux View Post
    I had a long and drawn out finding the problem with my rodeo..
    Surging and stalling... and loss of power down low
    i tried everything.. and was certain it was the fuel pump..
    untill one day i read some where to clean out the IAC valve.
    So sure enough i removed it and it was carboned up baaad..
    gave it a good clean. as well as giving the TB a good clean..
    It's been a diffrent car ever since...
    VY S Sedan
    Sep 2007
    This is usually caused by the immobiliser system,by either a faulty key head or loose screws that hold the remote to the key shaft.
    This problem only occurs if the vehicle is left unlocked for a period of time (20 - 30 seconds) then started again with the key.
    If you push the unlock button,even though it's already unlocked,this will disarm the immobiliser and the car will start.
    Get you mate to see what the red flashing light is doing with the ignition in the on position when it won't start.If it's still flashing,this means the key remote has not been read and the car will start,run for about one second,then stop.
    If you stuck a screwdriver in the ignition lock and forced the barrel around (don't do this!!)the same thing would happen,it would start,run,then stop.
  1. 98 - V6 VT wont start on first turn of engine
    By grafxworld in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2011, 11:23 AM
  2. Quadrajet mod to run strait gas
    By ported in forum V8 Development and Modification
    Last Post: 05-05-2007, 10:44 PM
  3. VN Calais Wont Start but will Turn over
    By mrhaboobi in forum Electrical Wiring / Questions
    Last Post: 20-09-2005, 09:18 PM
  4. turn clock back. vr statesman
    By gold statesman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2005, 06:32 PM
