Looking to fit a VY SS dash to my VY V6 will it all fit sweet?
Nope. Will have to change a few looms etc i believe.
Originally Posted by wikky
In the VY, the clusters are programmed by Tech2, so a V8 cluster can be used in a V6 provided the cluster is programmed by Tech2 at Holden. There are other means of programming, but I can't give much more guidance on that.
The major issue is that series 1 and 2 clusters are not fully compatiable. If the wrong series is installed, then the fuel guage will work backwards and DTE will be a useless function on the trip computer. Make sure that you get the compatiable cluster as the fix after installation is messy or expensive.
The Blue One
sorry if its a dumb question but what is tech 2?
Its a diagnostic tool, Holden uses to rectify, clear error msgs or run tests.
The Blue One
is there alternate software we can install on Laptop and do diagnoses,programming like tech 2 through laptop ???
Im not sure mate, but ive been thinking about it. As i have made up the necessary cable but just need the appropriate software.
Im going to see Phreddy (ASR) on Monday night & ask him, so ill let ya know.
The Blue One
Hi just curious as to how you went with this I'm interested too. Cheers
here is mine. I have a Vy series 2 ute. I fitted the level 3 hsv cluster. Had to take it to Holden and get them to calibrate it to suit my car. eg. 6 cyl, fuel tank size, diff ratio, auto and the set the k's too.
Dr.BOB who can still be found on here can do the work for you for $150, he can also supply the cluster. memcals.com.au is his site.
check out my build to see it going in. My VY ute s2. HSV MOCK UP
Check out my build <---Click me
Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
