Hi all,
Well my VY Monaro has had a few things fixed by the dealer under warranty but one issue always crept up, a roll over noise in the gear box. Once you lift the clutch the main bearings wurr in to action and it can be a little annoying but this does come with age.
Main issue I am having is that once you put it in 1, 2 or 3 and slowly take off you get this almost bearing a rattling itself to bits but once the revs pick up it disappears, when you down shift and coast in 2nd at low revs you get this amazingly annoying noise.
Does anyone have the same issue?
mine has a noise, but its an auto and it is shitting me not knowing what it is
