Results 1 to 14 of 14
Thread: VY Calais LSD?
    VY Clubsport
    Feb 2010
    Default VY Calais LSD?
    Hey, my first post here, i was wondering if the vy/vz calais V8 has an LSD in it?,, and if it does not, how hard would it be to put one in it, with the trac control and all the electronic gadgets?
    Thanks for all your help, i did do a search as to if this thread existed already, but it come up with nothing....
    02nelsc.
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    I think LSD was only standard on the SS models, & V8 Monaros. Its a straight swap to put a LSD in. Well worth the bucks , try & buy a complete unit with low klms off Ebay , around $350 , $400 odd. 3.07 ratio most popular, change the oil every 12 months .
    VY Clubsport
    Feb 2010
    Thanks, I was tossing up between the ss and the Calais, this will
    make the decision a little more easier.
    On the vy is there a tag or a plate that tells me the ratio, on the outside of the diff housing?
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by 02nelsc View Post
    1. I would have to differ with others here and say that the LSD was standard on all VYs fitted with V8. I just looked up the VY sales glossy (brochure) and it has the LSD listed as standard on the Sv8 which was essentially an "up-speced" executive with a V8. The sales glossy for the VZ also has the LSD listed as standard for the VZ Sv8. I am 99% sure that the LSD was fitted as a mandatory option to the Calais if you ordered the V8 on the VY. Unfortunately I don't have the Calais brochures but I don't believe GM produced any V8 VY or VZs without the LSD going into the car. They were also standard on the SS of course but the VY and VZ SS models were only V8s (as was the VX SS).
    (Driving a Commodore V8 in the wet without an LSD would be interesting).
    2. I ordered my current VY with an LSD and there is a metal tag on the diff and a white sticker on the side of the diff centre housing. As I recall it when I last looked the sticker had the diff ratio printed on it and is on the drivers side of the diff centre. The metal tag on the rear of the diff identifies the diff as being LSD.
    If you are tossing up between the V8 Calais and SS get a few insurance quotes on each car and I think you might find the Calais will be cheaper if the insured value of each is close.
    VY Clubsport
    Feb 2010
    no worries, thanks for your help, if i end up getting the calais i will let you know what it has in it, when i started looking for an upgrade for the old car i have now, the VY SS seemed like a good deal, but the calais, that has sunroof climate control full leather and electronics is the same price, i didn't know they were that price, they are a really nice looking car. If it does have an LSD in it, it should be quite spirited car too
    Once again, thanks for your help.
    May 2009
    VIC / NSW
    The VY and VZ Calais are both nice looking cars.
    Whilst I prefer the SS, if you are getting a used V8 Calais you are much less likely to get a vehicle that has been pre-thrashed than if you go for a used SS.
    So I would tend to go for the V8 Calais unless I knew the full background on the SS and it was one owner.
    Don't buy a car that has been in a company fleet (whether via full ownership or lease) at any time of its life because I can tell you from first hand experience that most (not all) of these types are cars are neglected in one way or another - especially on the mechanical side (like drivers that don't ever bother to check the oil and coolant levels between scheduled services).
    Sep 2007
    Thanks for update , you could be correct. You are correct about the LSD data plate being on drivers side of diff housing but it may be covered in road grime & hard to read. It has the ratio,part number , & whether its a LSD written on it with a large Barcode as well. , the tag is correct but there are 2 types of tag . One says "High Performance Diff" which means nothing much , the other says "Limited Slip Diff" , so make sure you get right under the car & read the tag.
    I have a 2003 VY Calais with Supercharged V6, a GREAT car. I have it chipped, 10psi pulley, extractors & R8 Clubsport exhaust My Sunroof was a Holden by Design option , they are not standard on Calais. My Calais did NOT have LSD in it , so was one of my first swaps. I agree ditch the SS , go for a Calais V8 preferably a series 2, around 2005 year. Or a VZ Calais V8 would be the ultimate but would be around the $18k to $20k mark I think. Good Hunting....
    VYII 5.7L V8 Calais
    Mar 2005
    Sydney, Australia
    im pretty sure my V8 Calais has an LSD in it (not sure if it was standard or optional).
    But I do have to say.....it is a really sweet ride - you get all the creature comforts with the grunt of an LS1.....I love it
    VY Clubsport
    Feb 2010
    ^^ My thoughts exactly, thanks for all your help, i will see if i can find the tag when i go shopping.
    vt calais
    Jun 2008
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    No bullshit way to find out if car has LSD:
    1. find tight bend.
    2. go around tight bend
    3. plant foot on accelerator at apex of corner.
    4. inspect road.
    BXHD Guest
    i thought Vz calais come stock with LSD? my VZ SV6 has LSD from factory...
    VZ Calais
    Jul 2009
    Quote Originally Posted by BXHD View Post
    The V8 Calais does, and the SV6. The V6 Calais had it as an option
    carless for now
    Feb 2007
    perth,Western Australia
    im pretty sure the ls1 calais and berlina were optioned but if you were going to get a v8 calais get a 06 vz with the l76 definetly worth the extra couple of grand
  1. [NSW] VK Door trims Berlina & Calais + VL Calais
    By vkberlina in forum Parts And Other Items For Sale
    Last Post: 03-10-2009, 07:41 PM
  2. [SA] vx calais altezza monaro lights and vt/vx calais doors
    By callum_88 in forum Parts And Other Items For Sale
    Last Post: 24-04-2009, 01:33 PM
  3. Replies: 0
    Last Post: 26-12-2007, 11:34 AM
  4. Replies: 57
    Last Post: 12-10-2006, 08:47 AM
