hey jus got a vy ss ute 2003 my 1st holden so dnt knoe much about them
my abs warning light came on n on the tirp cop abs fault? any ideas on wats going on wit it ? or should i take it in brake still wrk jus abs light came on
i find when i play around a bit doing burn outs and whatnot... generally on the dirt... that mine will come on.
all i've done in the past is keep going at it and sometimes it will go away, when it doesnt i just wait til the brakes are cool wash them with water and it will generally go away..
i dont know if what i do is a good solution but i figure the fault is only because of the dust everywhere a little clean is all it needs...
thanks i wrk it out happens bcos i power sided the bak wheels they where going so fast n the fronts aint movein as fast there 4 abs fault jus took the bat off for a few hrs all good now thanks![]()
either turn car off then back on, will go away, or take off neg batt terminal for a few minutes.
if that dont fix it, tech 2 to clear it.
