Results 1 to 6 of 6
Thread: Need help replacing a piece of interior
    VY II 3.8
    Feb 2009
    Default Need help replacing a piece of interior
    Hey guys
    I was moving my TV and went around a corner too quickly. Hello cracked interior piece.
    http://www.flickr.com/photos/sebastiengerard/4380226279
    Has anyone replaced this part before? The seatbelt runs through it and it looks like a pain in the ass but it bothers me so much knowing its cracked that i simply need to fix it some how.
    Anyone had any experience with this?
    Seb
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    VY II 3.8
    Feb 2009
    Jan 2010
    Bendigo, Victoria
    First off how did your TV get all the way up there?
    Second: remove the back seat, Remove the parcel shelf, remove the grab handle, remove the seat belt, and unclip the trim piece. Thats how I see it getting done.
    VY S V6 Ute Series II 2004
    Nov 2009
    (1) You have to remove the back seat cushion. Lift up the front of the seat cushion to expose the pull down release handles at either side of transmission tunnel. Pull them and remove Cushion.
    (2) Remove the two bolts holding the backrest to the floorpan
    (3) Lift the backrest frame from the hooks on the body panel near the parcel shelf and remove backrest.
    (4) Remove the bolt securing the rear seat belt buckle and belt to the floor pan of the car.
    (5) Remove the seat belt escutcheon from the "C" pillar trim, 2 screws in grip handle and one screw
    in "C" trim.
    (6) Gently prise trim away with a small screw driver (5 or 6 clips) and feed the seat belt through.
    When you're putting the back seat cushion back, put the cushion into place with the back of the cushion in under the back rests. Push down hard on the front of the cushion, pulling down on handle to help lock into place.
    Hope this helps.
    VY II 3.8
    Feb 2009
    Just a big tv i guess. Hope it still works actually...
    Thanks for the input, i'll get stuck into it over the weekend. Its a shame its not a part i can really upgrade while i'm at it :P
    Any more tips are appreciated to help me get it done smoothly
    Cheers!
  1. interior piece removal quarter glass area
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-03-2009, 12:30 AM
  2. Removing/Replacing Interior Door Handles
    By seraphic06 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2009, 03:06 PM
  3. Replacing Interior
    By Holden Chick in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2008, 12:04 AM
  4. wtb vn/vp interior trim piece
    By na3point8 in forum Swap / Wanted to Buy / Trade
    Last Post: 04-03-2006, 04:17 PM
  5. replacing interior on VP wagon
    By MarzVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-11-2005, 08:40 AM
