Results 1 to 2 of 2
Thread: Odd problem with battery when starting car
    VY Acclaim
    Aug 2009
    Default Odd problem with battery when starting car
    Sometimes when I go to start my car everything just blacks out, as if the battery just dies.
    Everything turns off , lights, head unit etc. I lose all my h.u presets..
    I have found that tapping the battery (ground connection) brings it back to life. Sometimes it takes a couple attempts, eventually the car starts.
    What could be causing this problem?
    Cheers,
    MK.
    Dec 2009
    loose or corroded ground terminal, take off the lead and clean the terminal and the clamp and reattach dont overtighten it and put vasolene on both terminals it stops corrosion.
    Then get the battery tested.
  1. battery problem
    By vpcommo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-03-2009, 11:12 PM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. Battery Problem
    By vl1234 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2007, 11:30 AM
  4. Orbital Deep Cycle / Starting 750cca Battery + BONUS
    By buzurk in forum Parts And Other Items For Sale
    Last Post: 24-06-2006, 10:17 PM
  5. Battery problem
    By G4orce in forum Car Audio
    Last Post: 24-07-2005, 11:29 PM
