yup as TMM said, Holden wont give you the code without the VIN number, even if you go to a dodgey holden shop they cant do it, as the sterios serial number and the VIN number it came with need to match properly, its done with a computer that merges the VIN and serial number so to speak to give out the code..
kinda the same way when you install a program on your computer and you need the serial key for the software..
so in the end dude keep away from it, its most likely stolen, or even if its not its not going to be any use to you lol
Where did you get that wrong bit of information from??
All that needs to be done is for a Holden dealer to fax a form away requesting the pin from the serial number from the unit.The VIN has nothing at all to do with it,the PIN is kept in Blaupunkt's (now Bosch's) records.
I've had a few radios that would not take the PIN that was on the owners card,stored in the BCM or on Holden's records.It usually turns out that a dealer or someone else has changed the unit without notifying Holden of the PIN and serial number change.
If you ever loose your PIN and it's the original radio,the number can be seen with TECH 2 from the BCM security settings.
That number is programmed into the BCM when the vehicle is built,but can be changed with TECH 2.The BCM does not know what radio is fitted because it doesn't have can-bus comms to the head unit like a VE does.
The number can also be looked up online in about 30 seconds by a Holden dealer.
If someone came into work that I didn't know and wanted a radio PIN,if it wasn't the number stored in the vehicles BCM or on Holden's records I probably wouldn't get the number for them unless they could prove where they legally got the radio from.
I can't believe anybody would waste their time stealing one of these units(even though they are piss-easy to remove),it was the first thing I took out of my VY.
