Results 1 to 14 of 14
Thread: Mystery plug taped to steering column?
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Default Mystery plug taped to steering column?
    It is a small, white, two pronged female plug, the wires running to it are blue with black line and black with yellow line? No it's not the diagnostics plug, what would it be do you reckon.
    VY S L67
    Nov 2007
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    VYII 5.7L V8 Calais
    Mar 2005
    Sydney, Australia
    VYII Berlina 3.8, VE Calais V 6L
    Aug 2005
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    As a guess I would say it may be related to the adjustable antenna memory system that is fitted to the higher end cars. It identifies the key inserted into the ignition and then sets the antenna to it's last recorded level.
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Okay thanks guys, could be a number of things, eh?
    WK Stato
    Oct 2008
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by crew chief View Post
    cabin temp sensor for climate control
    Aaaaah k thank you, so in other words it's pretty much useless for anything else!
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Spot on. Only used in cars with climate control air con, not the standard set up.
    May 2009
    VIC / NSW
    Quote Originally Posted by Calaber View Post
    Except that there are no climate control sensors located on the steering column or steering wheel on the climate control VY cars.
    There is one on the top of the dash for sunlight and one in the dash. The third is outside in front of the radiator.
    WK Stato
    Oct 2008
    Quote Originally Posted by Sean880 View Post
    correct, the sensor is located in the dash the wiring for it runs to this plug
    here is the wiring diagram showing the colours the op was chasing
    but hey could be wrong....
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Just because it's taped to a certain location doesn't mean that's where the fitting is located. The wiring codes for the sensor are definitely as described by VYmad. It could be that the location is convenient for assembly during production.
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Yeah, it seems to be just neatly taped up there on left side of steering column, visible with fuse panel removed.
  1. Adjusting the angle steering wheel / steering column
    By Kabooooom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2010, 05:12 PM
  2. steering column help!
    By Wadeo.. in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2008, 10:07 PM
  3. getting steering column cover off
    By reformed99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-07-2008, 06:40 PM
  4. Mystery Plug
    By andyman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2007, 11:38 AM
  5. vr steering column
    By 5Lvrss in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-03-2006, 06:47 PM
