Results 1 to 14 of 14
Thread: installing gauges into an SS induction gauge holder need help.
    Jemmo5ltr is offline Adrian
    VY Berlina
    Jun 2008
    Default installing gauges into an SS induction gauge holder need help.
    hey guys has anyone got one of those VY ss induction gauge holders? i got a few questions about gettin the gauges to sit in there.
    how do you actually get teh guages to stay in a snug fit there are no attachments with the gauges i brought that can hold them in there?? also need help with the wiring up on my water temp gauge. cheers!
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Quote Originally Posted by Jemmo5ltr View Post
    sounds like u have the exec fitment? if that is the case u will need to get a plate to hold it in place.
    water temp do u mean oil temp? as most i have seen have the oil temp
    VY Berlina
    Jun 2008
    sorry mate whats exec fittment?? and nah its a water temp gauge its one of those drift gauges
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    it means its for an executive and some of the holdens range had different fitmets ie coin holder there, and sounds like thats whats goin on,
    is it geuine?
    VY Berlina
    Jun 2008
    i reckon your thinking bout the wrong thing mate im talking about an after market gauge holder that sits above the climate control in VY's mine is a berlina
    VY Berlina
    Jun 2008
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    hey jemmo I've just done mine.
    Archer is on the right track, but he is thinking of the VZ model, which came with a bin up there.
    whereas VY's just had a blanking plate.
    I bought autometer guages for mine, and they came with the gauge holders. so it was a matter of running the loom down to the 12volt just below the stereo, and wiring up the gauges.
    you could try glue or silicone to keep the gauges in place, otherwise you will have to shell out for the holders, you can get them from autobarn or repco.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    Tyson23's Avatar
    Tyson23 is offline S-pack baby ;)
    VY Series II S-pack Ute M5
    Oct 2008
    Quote Originally Posted by sp001in View Post
    Hey mate,
    how did you find the 12v down below the stereo? a diagram or
    thanks
    _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
    _ _ _ 2004 VY Series II - S Ute in ReD _ _ _
    Hot House VY SS
    Jan 2010
    I think he actually means how do you get the gauges to sit snug in the holder itself, not how the holder fits onto the dash...
    If thats how I'm reading it then the gauges should come with a U-shaped bracket which mounts around the back and side of the gauge and clamps the gauge into the back of the holder. I personally wouldnt glue the gauges into the holder!
    Question - if I were to install oil temp and oil pressure gauges where can you get the feeds from?
    VY executive ute s1
    Jan 2009
    you'll need to swap the OEM oil pressure sender unit to one that should come with your gauge. Should be near the oil filter. However its advised to look for an adapter plate (such as on ebay or have one made) so you can use both the OEM and aftermarket sender.
    if you use the aftermarket sender, you wont get a warning light on your dash if your pressure drops. if you use the stock OEm sender on an aftermarket gauge, it wont read correct.
    To use an oil temp gauge you would either use one of those adapters for the pressure gauge, as there are usualy 3 or 4 holes for senders, or weld a thread into the oil pan same size as sender unit
    Hot House VY SS
    Jan 2010
    Thanks
    Yeah I dont want to be pulling out the oil pressure switch.
    Adaptor plate under the oil filter would def be the easiest way in theory but not sure if theres enough clearance for them on an LS1? Been doing a bit of searching and theres no mention of anyone using them..
    I started a separate thread for this question here
    Oil gauges install - can you use a sandwich adaptor?
    Calais
    Dec 2009
    Put some pics up, that way everyone can see, so they know there giving the right advice for the question.
    Hot House VY SS
    Jan 2010
    lastlegend's Avatar
    lastlegend is offline Phantom VY SS
    2003 Black VY SS + 1999 Silver VT Olympic Sedan
    Sep 2008
    Thorneside QLD
    Hi Mate,
    I am not sure about how the SS Inductions Gauge holders is manufactured but I just had the HSV R8 Gauge binnacle with Red matching guages fitted into my VY SS and the gauges are held in place by two methods.
    The first is a external threaded sleave which when screwed on and tightened holds the gauge in place - first you slip the gauge into the holder from the front and then screw on the external VDO Gauge sleave from the rear and tighen it against the houseing.
    Secondly there is a bracket that then bolts onto the back of the Guages to align them so they are straight and level.
    But as I said I am not sure what comes with the SS Inductions kit.
    say NO to chev badges -
    http://www.youtube.com/watch?v=MkeMvvm5sGA
    "I just got a new car for my wife today. Best trade I ever made."
  1. Aftermarket VY Binnacle gauge holder
    By MYDZYR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-12-2009, 01:14 PM
  2. [SA] Commodore gauge holder vt - vz
    By TUF UTE in forum Parts And Other Items For Sale
    Last Post: 04-05-2009, 10:05 PM
  3. [SA] pod holder & gauges for vy centre console
    By Macka21 in forum Swap / Wanted to Buy / Trade
    Last Post: 20-04-2009, 10:19 PM
  4. Installing gauges?
    By Silver surfer in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-11-2007, 09:58 AM
  5. Installing gauges?
    By Silver surfer in forum Electrical Wiring / Questions
    Last Post: 28-11-2007, 05:46 PM
