Results 1 to 8 of 8
Thread: Vy 03 radiator heating problem.....!!!!!!!!!!!!!!!!!!!!!!!!!!!
    commodore VY 2004 SS
    Jun 2009
    Angry Vy 03 radiator heating problem.....!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Hi All,,
    I have VY 2003, since two weeks im messed with radiator, the pressure on hose pipes seem reaches extreme due to heat if car is idle, twice the radiator got leaked and some time the pipe comes out from radiator due to high pressure. iv changed everything, pipes, thermostat,both fan relays, heat sensor,water pump, coolant but still the problem is same. both fans start at once after long time. i would like to add that when i start AC both fans start working immediately.
    well the temp gauge inside car stays at middle and shows no sign of overheat.
    please if any body can help me. im so frustrated because i spent alot but still the problem is same.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    **** me - how many threads to you have to start with exactly the same problem???
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    I would take your car to a competent mechanic that will properly diagnose the problem for you. Just changing everything on the cooling system in the hope you stumble on the cause of the problem -without knowing what it is - is not the way to go.
    Without inspecting and testing your car I doubt anyone here can tell you the cause of the problem. They will only be guessing. Don't delay as you don't want to blow a head gasket, crack the heads on the motor or cause other damage your engine from overheating.
    We can all have a "guess" at what the cause is but that's not very helpful to you.
    May 2009
    VIC / NSW
    May 2009
    VIC / NSW
    VY Commodore
    Aug 2010
    Default Vy commodore radiator probs
    I'm Having problems with my radiator the coil was replaced a year half ago steam is coming from around top hose joining to radiator. No leaks in hoses but when I start the car no waters going through hoses
    Ur thoughts guys
    VE SV6 Sportswagon
    Jan 2010
    Mornington Peninsula
    take it to holden
  1. heating problem
    By lyndon_breeze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2009, 08:31 AM
  2. Over heating problem
    By peanut_finger in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2009, 09:13 AM
  3. VR heating problem?
    By jimbojones889 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2009, 12:16 AM
  4. vt heating problem
    By VT1988 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2008, 10:23 PM
  5. Over Heating Problem
    By HSV_90 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2007, 11:27 AM
