Results 1 to 4 of 4
Thread: VY 5.7 l one tonner starting problems.
    VY11S one tonner
    Aug 2009
    Default VY 5.7 l one tonner starting problems.
    My ute has an intermittent starting problem. starts normally from cold, then when hot sometimes wont start first go so I turn the key of and start again with no problems. Can anyone give me a clue to why? Is it the crank angle sensor?
    VR 5ltr UTE
    Aug 2005
    Raymond Terrace
    Could be your key is buggered...
    Does it wind over and not start or is there nothing at all till you turn it off and on again?
    STOKED RACING
    Custom Modified Commodore Club
    http://cmcc.7.forumer.com/index.php
    VYII 5.7L V8 Calais
    Mar 2005
    Sydney, Australia
    I had a similar problem with a VS and turn out the key was rooted.
    You could run a diagnostic test on it to see if something comes up.
    VS V8 ute
    Dec 2006
    Is it turning over but wont fire? My cross 8 crewman dose this, its all ok when its cold but when its hot it wont fire. There is some black smoke out of the exhaust I noticed a couple of times when my wife started it when it has done this, that would indicate a bit of flooding. Will start firstly with the temperature sender then maybe crank angle sensor. Ill let you know how it goes.
  1. starting problems
    By synical in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-10-2007, 06:45 PM
  2. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  3. Diff Problems Crewman "S" & 1 Tonner V6
    By Fitzy44 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-08-2005, 03:10 PM
  4. Starting problems
    By Chris in forum General
    Last Post: 30-06-2004, 09:17 PM
