Results 1 to 14 of 14
Thread: break shudder at higher speeds
    Mercedes C200K AMG-Sports
    Mar 2007
    Default UPDATE! break shudder at higher speeds
    I know I've posted regarding steering shudder before but this one is a bit different.
    When I drive at 100km and I get the slight shudder, I then break at from 100-80km i get a shake when braking pretty bad. but if I drive at 100km and it does not shudder, I do not get the brake shudder.
    Would a break pad machining repair this? I got it machined last service and it did take away the break shudder but not the cruzing shudder.
    VY LS1 Berlina Wagon
    Jun 2006
    How long ago was the service?
    You said you had the disks machined last service and the brake shudder went away, would you say that it has come back the same as it was now?
    Is there anything the brings on the shuddering when cruising? Are your wheels aligned correctly? How are your tyres waring?
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    So do you get a shudder when cruising with out braking? or is it as soon as you put on the brakes and gets worse the harder you press them?
    If it does it just when cruising, then dissappears at or over 100km/h, I'd have a look at your wheels, get (at least) the front wheels balanced/checked for uneven tyre wear.
    If its only when your braking it'd most likely be the front discs/rotors. It doesn't take much to get them too hot so they warp, one big long brake application CAN warp them.
    Around $60 for each new front standard rotor is all you should be paying - if you have someone that doesn't rip you off
    Mar 2007
    Quote Originally Posted by doobs View Post
    I've spent too much time and money figuring this out. The light cruzing shudder gets less when I pump up the tyres to 40psi. But the break shudder is new.
    Last service was 5000km ago.
    MY04 VZ SS A4
    Feb 2007
    North Shore, Auckland, NZ
    I have the same issue, only mine appeared after a service when the mechanics skimmed the brake rotors and replaced the pads ... I tell you what, it's bloody annoying!
    If computers have no doors or fences, who needs Windows and Gates?
    Dec 2009
    Quote Originally Posted by anonymousmoose View Post
    What sort of tyres are they? I had some Toyo's once and the front vibrated when I first drove the car after it had been sitting for a few days, once the tyres warmed up it usually went away. However sometimes the car vibrated at speed but not always. You could try rotating the tyres it sounds like they are out of round. Another trick get the tyres rotated on the rim a bit, TOYO did that for me and it helped.
    I would't bother with machining the brakes just get new rotors, I'd try the RDA slotted. There easy enough to put on yourself and a set would be about $150.00. You just have to make sure the hub surface is clean of rust and scale, use a wire wheel on a drill and put a bit f grease on the centre bit that sticks out through the centre of the disc.
    If your pads are good you can try rubbing them with sand paper on a block of wood but if there more than say 1/2 worn get new ones as well. AC Delco from Holden dealers are good and about $50 a set for the front.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Either u need a front tyre balance or the tyres are unevenly worn.
    I had this issue on Sunday when i went for a drive up nth, i did a front to rear tyre change on saturday. Got all 4 tyres balanced yesterday no issues at all.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Mar 2007
    Quote Originally Posted by wortus View Post
    I just got brand new continentals put on last week.
    Mar 2007
    Quote Originally Posted by PaulSV6 View Post
    Na, been blanace about 5 times in the past year and new tyres a week ago.
    VZ AWD One Tonner
    Jul 2006
    Bearings, which leads to rotor DTV...
    Common Problems in Holden VT fitting TB 07
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VY UTE V6 ECOTEC
    May 2005
    Cool Tyre / wheel shake....
    GDAY MATE....
    Ah yes the shake issue.....
    This might sound dumb but check exhaust system you might of bent the first mufflet alittle bit...
    Look at my thread i have been chasing a tyre shake for some time...
    I got a shake at 100kmph + and i couldnt drive through it got worse...
    The 3 major things to look for is
    Wheels / Tyres / Wheel Balance
    If you have a ute get a IRS camber kit for it so you can align the rear.. helps shake..heaps
    Drivesharft / Tailshaft
    Loose or worn componets like rubber dampers...
    Exhaust...
    Look for bent or loose components...
    My 2c RIK...
    Mar 2007
    Default Good news!
    Good news, the steering shudder is completely gone now when driving it at 100km. First time since I owned the car. Barbagello tyres re-balanced my wheels.
    However the shudder is still and only there when I break from 100-80km/h. I will get the brakes re-done. I think the discs got warped in the Perth storm. The pads must have been hot when I drove in and out of the deep water puddles. Could this be it? But why then only shudders from 100 down to 80km/h
    con7502003 is offline Banned
    vn 5ltr
    Jun 2009
    warrnambool
    just check your wheels for run out got simmilar prob if you have hit a gutter hard you might have slight buckel in one of ya wheels
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    caster bushes.
  1. VZ shudder higer speeds
    By andrewmac in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-09-2007, 11:12 PM
  2. break shudder
    By jacque@nobbys.net.au in forum General Discussion
    Last Post: 25-04-2006, 01:21 AM
  3. Fan Speeds Vs
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2006, 01:58 PM
  4. break pads? price? vt break conversion?
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-09-2005, 06:02 PM
  5. Only Three Fan Speeds.
    By d hsv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2003, 12:03 PM
