Results 1 to 2 of 2
Thread: Help to get vy brakes working after abs removal
    VK Group a and VZ
    Oct 2009
    Default Help to get vy brakes working after abs removal
    Hi all,
    Just removed ABS from race car and reconnect lines back up, front of master cyl outlet to front brakes and rear outlet to rear. Now under hard braking the front lock up and hold a bit of pressure while turning into the corner. May this happen because I have put the pipes on as above? Does the front master cylinder outlet actually go to the rear brakes?
    Any info would be great.
    Ash
    VY SII HBD Calais L67
    Dec 2006
    You will need a brakeforce proportioning valve from a factory non ABS car. It distributed brake pressure more evenly
    VYII Calais L67
  1. Replies: 2
    Last Post: 07-10-2009, 02:40 PM
  2. vp abs brakes
    By LESK1946 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-09-2009, 04:28 PM
  3. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 10:41 AM
  4. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  5. Brakes
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-12-2005, 07:42 AM
