Results 1 to 21 of 21
Thread: Fe3 suspension in a vy?
    vh
    Dec 2009
    Default Fe3 suspension in a vy?
    I was just wondering is it possible? I don't believe anyone has asked this question before on these forums and there is limited info about it.
    Any info would be great thanks
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Quote Originally Posted by smi5575 View Post
    What's FE3? FE1 is the standard suspension, FE2 is the sports suspension, and FR1 is the country pack suspension. Don't think I've heard of FE3.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    vh
    Dec 2009
    Well its in the new cadilaic and gxp pontiac, which got axed. the pontiac is basically a ve commodore with a slightly bigger engine so im and the suspension and all was all designed and built in Australia. google it
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Isn't FE3 the suspension you can get as an option on the VE's?
    If that is the case, then no, you can't put it on a VY.
    VYII Berlina 3.8, VE Calais V 6L
    Aug 2005
    Quote Originally Posted by danja View Post
    Don't forget FE1.5 on the Calais....
    Never heard of FE3 though mate.
    vh
    Dec 2009
    Quote Originally Posted by Jesterarts View Post
    oh ok fair enough. do you mind me asking why?
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    because the VE and VY are TOTALLY different.
    The Black Beauty
    vh
    Dec 2009
    Quote Originally Posted by TVR-161 View Post
    yer no shit but how?
    vh
    Dec 2009
    Sorry I want to make myself a bit clearer here. I know that FE3 is different and better. But what makes it better than its predecessors?
    FE3 is all the rave at the moment especially in America, the 09 cadaliac was clocked at under 8 mins in the nurburg ring, which truly demonstrates the true performance and handaling capacity of an FE3 and and Ls3 combination in a large car. In short FE3 is a great on the track and smooth on the streets.
    So what makes is so good? And is there any improvements you could do to the vy set up to get the great track handling and smooth street feel you get with the current FE3?
    I know this topic has not been covered much. So if you don't know what FE3 is please don't post until you do.
    danja's Avatar
    Jan 2006
    Well the VE is a completely different platform/chassis. You may as well ask if FG Falcon suspension will fit your VY.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    The suspension design of the VY dates back to the VR, which was in itself adopted from earlier models of Opel. The VE was a completely new design, which, although sharing the same basic layout, shares no components with the earlier models.
    You also shouldn't confuse the chassis from the Cadillac with the VE or G8. Those two use GM's Zeta platform, whereas the platform used in the Cadillac is called the Sigma. It is a much more expensive and involved suspension and floorfpan design than the Zeta. FE3 would be a variant of that platform. In the GXP, it would have been a custom version of the standard Commie set-up, possibly something like an HSV set-up.
    Zeta was designed for lower priced GM models such as Commodore, Camaro, etc (remembering that the G8 was the result of Bob Lutz, erstwhile GM head honcho, visiting Aus and liking the VE so much, he felt it had a place in the States as a Pontiac - it wasn't originally designed to be marketed that way). The Sigma was a premium platform, designed for Cadillac, SAAB (I think) and other upper market GM products - I think it might also be used in the Vauxhall/Opel Insignia, which replaced the Vectra.
    vh
    Dec 2009
    Oh ok thanks calaber that's very interesting. It's good that someone on here actually knows what there talking about lol.
    What suspension set up would you recommend for the occasional circuit but mainly street driven vy? The G8 is know for its European styled handling, in your opinion would it be possible to achieve such handling traits such on a VY?
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    ONe of the biggest improvements in the VE chassis over the VY-VZ was its stiffness - the VE body is much stronger and more rigid than the earlier body. That stiffness and strength is a major reason why the VE handles so much better than previous Commodores. You won't be able to get that degree of body integrity in your VY, but you can still get plenty of improvement by talking to suspension specialists as suggested, to work out the best combination of springs, dampers (shocks), sway bars, bushes and steering geometry. Remember that good handling requires much more than just stiffer, lowered suspension and hard shocks. The whole suspension needs to be set up according to your needs. If you want to include some track work, that would be factored in by the specialists when setting up your suspension specs.
  15. #15
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    In a nutshell, to acheive the same results in a VY as you do putting FE3 in a VE, you would need to do ALOT or work to the VY chassis.
    Just to give you an idea of what you are up against, I have 21yo BMW which has suspension which is basically IDENTICAL to the VT - VZ setup.
    Holden was lagging a long way in terms of suspension technology until they built the new VE ground up.
    In order to get decent handling from a VY you've looking at new stiffer/lower springs with shocks to match, performance swaybars, replacing all bushes, adjustable camber kits, etc.
    And even once you have the suspension perfect, you've still got to deal with the fact the VT - VZ doesn't have 50/50 weight distribution unlike the VE which is alot better in this aspect.
    And that's alot of money to spend on a car that's only going to see a track 'occasionally'.
  16. #16
    danja's Avatar
    Jan 2006
    I seem to recall the VT having something like a 52/48 distribution, which isn't far off. As far as handling balance goes, with the right sway bars they aren't too bad, but the chassis is not particularly rigid as Calaber points out, which contributes a lot to the infamous "boat" handling.
  17. #17
    vh
    Dec 2009
    Fair enough thanks for the input. That's an interesting read. I don't necessarily want want FE3 just a set up that has similar characteristics as it.
    Any recommendations?
  18. #18
    vh
    Dec 2009
    Quote Originally Posted by Calaber View Post
    Thanks for the info that has helped me a lot, and very interesting. Where did you get all this info?
    Once I finish my training in the army I will have more than enough funds to pay the pros to get me a good set up, I'm looking foreword it it
    thanks again
  19. #19
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    thanks again
    Just reading a lot about the VE when it was released, and being a mad Holden man for over forty years, plus owning about 15 different models over that time, I guess.
  20. #20
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
  21. #21
    vh
    Dec 2009
    Lol Fair enough. i guess I'm only 19 and i could learn a lot from people like you, thanks for the advice
  1. suspension, let me see if i got this right
    By sictj in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-08-2009, 05:24 PM
  2. Replies: 1
    Last Post: 18-03-2009, 07:26 PM
  3. FE2 SUSPENSION. how low will it go
    By madvrcom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2007, 06:24 PM
  4. Suspension
    By AlX in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-03-2006, 08:04 AM
  5. VH Suspension
    By mza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-03-2006, 11:45 AM
