Results 1 to 10 of 10
Thread: Boot Wont Open. Aberrantly valet Locked.
    Mercedes C200K AMG-Sports
    Mar 2007
    Default Boot Wont Open. Apparently valet Locked.
    My boot wont open by the key, only the manual release inside the back seat.
    I called my mechanic, its going in for a service Saturday anyways, and he told me that holden has a lock mechanism and he knows how to 'unlock it'. Apparently its some sort of valet lock so when you give the car to a parking valet they cant open the boot. He said I must have bumped the locking mechanism.
    Rather then wait until Saturday, can anyone here tell me how to turn off the valet thing? Its a Holden Caprice WK.
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Quote Originally Posted by anonymousmoose View Post
    Try disconnecting the battery , (After noting the radio pin code) it should default back to normal after battery is reconnected.
    VY S Pac
    Mar 2010
    Same thing has happened to my VY.
    I disconnected the battery and it still has the same issue.
    Mar 2007
    Oh well, going in for a service tomorrow and my mechanic used to work for Holden and says he knows exactly what it is.
    VZ SS-Z
    May 2006
    You'll probably get this sorted tomorrow anyway, but does the remote release in the glove box work?
    VYII 5.7L V8 Calais
    Mar 2005
    Sydney, Australia
    i was playing around with the latch on my old vx one day and im pretty sure theres a little switch on the side that locks/unlocks the latch.
    VY S Pac
    Mar 2010
    What was the result of the service on Saturday?
    VY S Sedan
    Sep 2007
    If you can hear the actuator moving when pressing the remote it is most likely that the rod that connects the actuator to the latch is broken.
    VX II
    Oct 2010
    I had this problem and the rod between the actuator and the latch was broken.
    Open the boot with the yellow manual cable pull from the splitfold seat opening.
    Look into the boot lid cavity and press the boot open button on your keys. You will see the actuator working or not working. If it is working see if it has a thin metal rod to the latch. This is probably broken.
    Does anyone know which part I need to buy?
    1. Just the wire?
    2. Another latch?
    3. Another actuator?
    4. Another car? ;-)
    VY II Calais
    Nov 2008
    I had the same problem, when I pressed the boot release on the remote the noise worked (i.e the actuator) but the wire was broken and wouldn't release. Then when I pulled the rip cord (the yellow) it opened fine, so I just made another wire out of a coathanger and its been fine since. Its a bit of trial and error for the length but was easy enough. In saying that I'm sure I have read on here previously someone had theirs fixed during a service at the dealer with a whole new unit for only $80. I'd almost save yourself the hassle and do that.
    I however have a Calais, but maybe the Caprice does have a valet lock, in which case surely it would be in the manual how to disable it?
  1. locked keys in boot and i have no spare...
    By lowrida56 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-11-2008, 06:17 PM
  2. Help. Locked keys in boot :(
    By Fletch_QLD in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2008, 05:19 PM
  3. Door locked wont open???
    By reddog in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-07-2008, 07:49 PM
  4. how to open a locked cabinet?
    By Torquative in forum The Pub
    Last Post: 19-03-2008, 01:30 PM
  5. Urgent Help Please - Locked Boot
    By vaughan in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-05-2006, 01:12 AM
