Results 1 to 4 of 4
Thread: vy v8 trans cooler
    vnss
    Jan 2007
    wyndhamvale vic
    Default vy v8 trans cooler
    Hi guys was just wondering if anyone can help me, i getting a vy v8 soon with tricked up gearbox and was just wondering if its possible to by pass the radiator and just have a stand alone trans cooler. if so what sort would you recommend would it be big enough to do the job or should i just use it in conjunction with the radiator set up? cheers
    sixes's Avatar
    sixes is offline UTEPILOT
    VY SS II M6 Ute
    May 2004
    Townsville QLD
    Nothing wrong with running a stand alone cooler just depends where you are and how much stop / start driving you do. There might be 2 brackets in front of the radiator ready to bolt up a trans cooler otherwise the brackets are about $30 from Holden (simple bolt in job)
    Personally I would run an external cooler and have it run back through your radiator.
    I used a large TCI brand on my old VX SS and the trans temps were reduced very well.
    VY LS1 Berlina Wagon
    Jun 2006
    Ey mate,
    I run a separate transmission cooler, bypassing the radiator, has dropped the temps by about 15C. I decided to bypass the radiator just in case it fails and coolant gets into the transmission or vice versa.
    FYI my temps before the cooler where: 55C to 60C when cruising and upto 80C when stop starting and driving hard
    After the cooler was installed: below 50C (thats as low as my gauge read) cruising and max of 65C when driving hard
    vnss
    Jan 2007
    wyndhamvale vic
    thanks guys, yeah im more inclined to go bypass the radiator. i know they build radiators better now days but just in case.
  1. [VIC] V6 PWR Trans Cooler
    By VSEXEC in forum Parts And Other Items For Sale
    Last Post: 02-02-2010, 08:18 PM
  2. VS Trans cooler
    By hespie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2009, 01:25 AM
  3. Trans cooler, what to get?
    By esaad in forum V8 Development and Modification
    Last Post: 17-11-2009, 12:58 PM
  4. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  5. VR Trans Cooler
    By Mk III the HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2005, 10:54 PM
