Results 1 to 16 of 16
Thread: High Flow Cats, worth it?
    VY II Berlina V6
    Apr 2010
    Perth, Western Australia
    Default High Flow Cats, worth it?
    I've been collecting some quotes on a new exhaust system (headers to the tips) and noticed the single biggest cost in these systems are the cats (since the VY has two of the bastards).
    Is it worth replacing the factory pieces or do they flow well enough for the average cruising mobile (I'm not racing the thing)? No doubt there would be some restriction alone with the size of the entry and exit pipes to the factory cats.
    Most of the quotes have been around $1900 fitted although usually $800 of this is due to the cats alone.
    I browsed the exhaust threads in the FAQs but they were more about sound and few specifically dealt with cats.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    On a V6 with twin cats anyway, no, the stock cats will flow plenty. It's only when going forced induction will you need to go with high flow cats.
    As a comparison, I do 200cpi metal high flow cats at $198 each.
    Visit my Facebook page
    Holden VN SS
    Mar 2010
    Quote Originally Posted by Not_An_Abba_Fan View Post
    What do u do stock 5 litre cats for?
    sixes's Avatar
    sixes is offline UTEPILOT
    VY SS II M6 Ute
    May 2004
    Townsville QLD
    I can't justify the cost of buying new cats. All depends on what you plan on doing for modification wise but in your case just get your original cats opened up if you are concerned. By that, get larger in and out pipes welded on. They flow well when this mod is done and costs bugger all to do and saves you cash for other things
    Holden VN SS
    Mar 2010
    they do make a difference high flow cats, unless u got a 355 the 5 litre cats flow fine & actually have better low end take off with stock cats as sopposed to the high flow which have a bit more top end give on a 5 litre.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    i have a supercharged vx and was wondering if a hi flow cat would help with the back pressure problem im having, car revs up as i push the clutch in
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    sixes's Avatar
    VY SS II M6 Ute
    May 2004
    Townsville QLD
    For sure they make a difference but its cheaper just to open up your stock cats as they perform very well
    Styled by Holden, Powered by Chev
    Delish-VY's Avatar
    Delish-VY is offline Steve
    2003 VY S pack
    Jan 2010
    Originally - Eastern Suburbs - Melbourne, Currently - Cairns
    Quote Originally Posted by sixes View Post
    remember that gutting ur cat is illegal so if cops check that out ule get canaried...but at the same time unless ur exhaust is whistling like a ferrari I doubt they"re gonna go to the effort of dismantling them just to see if u gutted them
    My VY S-Pack
    Quote Originally Posted by wraith View Post
    Don't ruin a good story with facts.
    Pet Peeves - V6 Modded Exhausts - Rims on Front/Stockies on back - Chev Badges - Kitted cars with trolley strips - Fusion & it's fanboys
    Having less rights than a balinese prison
    carless for now
    Feb 2007
    perth,Western Australia
    Quote Originally Posted by Delish-VY View Post
    i think he means opening the flanges up not gutting them
    sixes's Avatar
    VY SS II M6 Ute
    May 2004
    Townsville QLD
    Thats right, I didn't say gutting
    All you do is get the original pipes / flanges cut off to where they meet the actual body of the cat. Then larger pipes or flanges welded on. This mod increases flow while remaining perfectly legal Have done this mod on the last few cars I have had and not only does it save you huge $$$ over buying new cats, but is a cheap way to gain more out of stock ones which do flow well with larger pipes put on.
    Be aware too that some of the metal cats actually do not pass EPA. They can flow too much so they don't work as well converting the toxic nasties allowing the plod to whack on a nice sticker if they check it.
    Delish-VY's Avatar
    2003 VY S pack
    Jan 2010
    Quote Originally Posted by Vt_vic View Post
    My mistake gents, a mate of mine suggested I gut my cats about 3 weeks after I got my car n he explained it gives more power n all that, n I was like..oh yeah sounds like a good idea, then hes ....but its massively illegal lol
    My VY S-Pack
    sixes's Avatar
    VY SS II M6 Ute
    May 2004
    Townsville QLD
    If you were going to gut your cats, get a pipe welded through the cat so it flows straight through. Not doing so causes the exhaust gas to swirl in the empty cat and slowing the exit, it can also makes a funny noise. And yes, not running cats is illegal and there are some big fines, especially for your guys down south. The NT doesnt have EPA nazis as such
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    lol the coppers have temperature sensing gadgets now, its as easy as a press of a button to work out if they've been gutted
    Holden VN SS
    Mar 2010
    yep & a known fact is that with a gutted cat your Mild Steel exhaust will rust on the surface or possibly inner a hell of alot quicker.
  15. #15
    carless for now
    Feb 2007
    gutting it would give you stuff all of a gain anyway at 200 for a high flow cat you dont really have much to lose
  16. #16
    Redline SSV
    Jun 2008
    +1 on that. V6 doesnt need em. V8 then it would help.
  1. Difillipo Extractors and High Flow Cats
    By bluevzssute in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-07-2009, 06:55 PM
  2. High flow cats
    By H1GHROLLR in forum LSx Development and Modification
    Last Post: 01-03-2009, 07:53 PM
  3. What high flow cats to use??
    By Breno in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-02-2009, 05:24 PM
  4. HPC coating and high flow cats questions
    By BANKS in forum General
    Last Post: 01-08-2008, 09:11 AM
  5. High flow cats and extractors
    By gamevx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2007, 07:54 PM
