Results 1 to 10 of 10
Thread: Lower on left..
    VY Calais
    Feb 2010
    Default Lower on left..
    Can some1 help, i got my car recently SSL kings in the rear on my VY Calais and iv noticed that the left side it noticabley lower 1-2 cms the car is sitting lower than the rims when the right side it sitting perfectly mid tyre.. any ideas?
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    id also like to know. mine does it too. only in the rear. gonna try and get a new diff cradle. possibly kinked.
    WH caprice , 2010 Holden CDX Cruze
    May 2008
    Dan VS 231's Avatar
    Dan VS 231 is offline Ell Sixty Seven
    VY Calais L67
    Jun 2008
    Perth W.A.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    You havent put the spring in upside down have u?
    Also check ur rear tyre pressure's.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    You will not get an exact matched height either side front or rear - there will always be some slight variation but just a few mms. However the difference should never be as much as 1-2 cms each side.
    I would suggest the springs used are of questionable quality and that the spring rate is different on each side. (If you did not have the problem with the previous spring "balance" on the car, and you have changed nothing else, then surely the new ones are the culprit). If the spring compression is greater on one side than the other because of badly matched or manufactured springs (and it probably is) then you will obviously get a greater drop on one side of the car.
    As you say it has been done recently I would be going back to the fitter and asking for the job to be rectified. Just don't let them get away with some BS story that what you have is normal and within acceptable tolerances because it is not if you have such a great variation in height. They will also try to fob you off with a story about the springs settling. If the springs were of identical spec each side then they will settle at the same rate also and you would not get such a wide difference.
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    i tried 2 sets of springs, both were the same afterwards. couldnt remember wat the standard was like. :S
    VY SS S2 Utility 2004
    Dec 2009
    Melbourne, Inner.
    mine does it too, but only since i jacked up one side of the car and not the other at the same time, my mate said that it can make the springs go wierd, he may be wrong but it seems to have happened lol.
    livin' the low life.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    make sure u put the springs in the same, twist them around so there both got the cut bit facing the front, fixed mine
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    May 2009
    VIC / NSW
    Quote Originally Posted by VTPREDATOR View Post
    i tried 2 sets of springs, both were the same afterwards. couldn't remember what the standard was like. :S
    I suggest the springs are suspect if you are getting 1-2 cm variance side to side, and assuming nothing else has been modified and the springs have been seated correctly.
    I have standard Fe2 suspension on my car (untouched) and I did a quick measure on each rear side after the car had been sitting quite a few hours. The difference in height from a bottom point of the rear wheel arch panel to the centre of the wheel on each side only varied side to side by about 4 mm which is not unusual. I have never found them to be precisely the same to the last mm on Commodores. On my car the passenger side rear is sitting very slightly higher at the measuring point than the drivers side rear and I have nearly a 7/8 full tank of fuel. The difference side to side is so small it is not discernible to the eye.
    Yes the springs have to settle after you have jacked up the body but I have done this numerous times on my car on all 4 corners and have not had height balance issues or spring distortion afterwards.
    I have also had low springs fitted on a few previous commodores and have never had any height balance issues or any spring distortion due to jacking the body. ( If you get distortion or other problems I would seriously question the quality of the springs).
    With springs you get what you pay for. It would be interesting to know if anyone has had the height imbalance problem complained of here with Pedders lowered rear springs.
  1. O2 sensors, right left, left right ???????
    By pando666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2009, 07:01 PM
  2. PoLL: lower back or lower front????
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-07-2008, 09:55 AM
  3. Lower????
    By G4orce in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2007, 05:02 PM
  4. How much lower?
    By ::Team420:: in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2006, 09:59 PM
