Results 1 to 2 of 2
Thread: vy ss II traction control stuck on
    VE Thunder SS ute
    Jun 2009
    Keilor Downs
    Default vy ss II traction control stuck on
    hi guys,
    Iv just picked up a vy ss series 2 and figured out half way home when i wanted to see what it could do that when i push the traction control button it dose not turn it off.
    Can anyone please help me with this
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    If the TC button does not turn the system off and on when the engine is running then if you are lucky it is possibly a faulty switch. However failure to turn off the system , (ie the TC system off indicator does not display when you press the button to turn it off) is usually an indication that the TC system is not working at all and hence you have NO operational TC.
    Even when switched off manually, when working correctly the system is automatically turned on again every time you re-start you car or you just turn the ignition on. In your case it is quite likely that your TC is not working so you should get it checked out.
  1. stability control...traction control???
    By m05tw4nt3d in forum VE Holden Commodore (2006 - ?)
    Last Post: 28-03-2011, 09:30 PM
  2. traction control
    By kingwalker in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2009, 08:26 PM
  3. Traction control stuck on
    By matt'sVS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-06-2008, 12:31 AM
  4. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  5. vy sv6 traction control
    By phat_com in forum General
    Last Post: 11-01-2007, 03:56 PM
