Results 1 to 19 of 19
Thread: What is this pulley and why is it making an annoying whistle?
    VZ SS Thunder 6L
    Jul 2008
    Castle hill
    Default What is this pulley and why is it making an annoying whistle?
    The name really speaks for itself.. I've pinpointed the source of a rather annoying whistling coming from my engine bay and it seems to be coming from that pulley(circled in the photo). Can anyone tell me A) what it is and B) how do i fix it?
    Cheers.
    Tim
    Attached Thumbnails Attached Thumbnails What is this pulley and why is it making an annoying whistle?-bay.jpg
    Check out my ride!
    VYII S
    Jun 2008
    ecotec engine.. Im going to go out on a limb and say its the air con compressor?. Im a bit drunk, but looking at my own ecotec, thats what i assume it is, since its hanging off the side.
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    I'm going to say air conditioner? Just went and looked at mine.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Definitely is air-con compressor.
    Ronald Reagan (1986)
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    be your air con dude, does it make the noise when its turned on off or both?
    VZ SS Thunder 6L
    Jul 2008
    Castle hill
    Thanks for the replies! The noise is always there regardless of the air con being on or off.
    Check out my ride!
    -scyth-'s Avatar
    -scyth- is offline Im alright its the others
    VZ Wagon 05
    Nov 2008
    VY s m5 supercharged
    Aug 2008
    Does it change in sound with the rpm of the motor?? i had my pulley/clutch replaced under warranty as the it was faulty
    and yes its the AC
    VS l67 statesman
    Dec 2008
    I had the bearing shit itself in the aircon pulley in my Vp ,it sounded like a low power steering fluid noise and was there reguardless if the aircon was running I managed to replace the bearing while the compressor was in the car
    VZ SS Thunder 6L
    Jul 2008
    Castle hill
    Doesn't change with rpms. Sounds similar to what vsl67 described. If it helps I'll record the vid and post on YouTube
    Check out my ride!
    04 vy 2 s ute
    Mar 2010
    just replace them all i got mine done like 1 weeks ago was making the noice etc... if u dont change them fan belt can come of.. cost me 20 bucks per pulley plus labour so like 380 all up
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Make sure it is that one I just had my Idler pulley go which is the small one above the one you have pointed out squealed like a bitch bought a new one for $32 fitted it myself all good now.
    VZ SS Thunder 6L
    Jul 2008
    Castle hill
    Quote Originally Posted by G.C.Photography View Post
    hmm that's good to know.. i think i'll replace it anyway being $32.
    Well i've noticed the noise comes and goes.. i dont think its warmth related.
    Check out my ride!
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by Timmos View Post
    fair chance it will be the little 1 above the aircon as id say it would change with the aircon on or off if it was the aircon.
  15. #15
    VZ SS Thunder 6L
    Jul 2008
    Castle hill
  16. #16
    04 vy 2 s ute
    Mar 2010
  17. #17
    02 VY SS
    Apr 2010
    Before you go changing random pulleys chasing a whistle, Sparay a little crc on each one with engine running to isolate the one thats making the noise. saves time and money. Due to it being a single belt drive vibrations and nosie can be transmitted kinda like a ventriloquist throwing his voice, no point chasing your tail. Thats advice given to me by a trained holden mechanic, so id thought i would share .
    VZ SS Thunder 6L
    Jul 2008
    Castle hill
    Thanks and yeah good advise.. i'll do that...
    My mechanic mate showed me a little trick to isolate noises like this, he got a long flathead screwdriver and placed the end of the head on the bolt of the pulley....you can hear the noise travel through the screwdriver if you put your ear to it.
    If that does work, it's apparently the pulley 2 up from the aircon compressor..
    Check out my ride!
  19. #19
    02 VY SS
    Apr 2010
    yup it does work kinds like a stethescope which you can buy for a few bucks at supercheap handy for lots of things
  1. [VIC] WTB: SC14 6PSI Pulley & 12Psi Pulley
    By Bz Kn33z in forum Swap / Wanted to Buy / Trade
    Last Post: 20-05-2009, 12:08 AM
  2. New A/C idler pulley making noise
    By aceventura in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2009, 09:30 PM
  3. whistle
    By vr-man in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2008, 08:33 PM
  4. whistle
    By vg_ute in forum General
    Last Post: 28-10-2005, 08:27 PM
  5. whistle on LPG
    By ntl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2004, 06:46 PM
