Results 1 to 7 of 7
Thread: On-car disk machining
    VY executive ute s1
    Jan 2009
    Default On-car disk machining
    due to uni and work commitments, im having a hard time finding time to give up the car for a day. Ive been looking for afew mobile machining guys, and before i go to far into it (coz they're a bitcht to find)
    Does anyone know if they are able to do this with a regular VY rear disk? Some peopl have said it cant be done because its no actualy bolted to the hub, unlike most 4wd ro front wheel drive cars. Is this true???
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    There are such blokes that will machine from the back of there utes.. As far as them removing and replacing them for you, I have my doubts (that'll be your job). To be honest if it's a stock rotor just buy a new new one as there not that much coin
    Cheers,
    Dave
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I agree with just getting new discs, not much different in price. Also to hold the discs on the hub while machining you just put the wheel nuts back on.
    Ronald Reagan (1986)
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by VY_utester View Post
    Don't waste your time. New quality rotors are quite cheap to buy for Commodores (eg AC DElCO under 90 per disc). Buy them and book into a brake shop or workshop to have them changed over. You will be in and out in less than 1.5 hours. If the brake pads are low you should get them done at the same time to save future labour charges.
    VX Berlina
    Apr 2007
    Quote Originally Posted by Sean880 View Post
    $90, bugger that. GSLRallySport, a sponsor here on the forums will sell RDA standard rotors at $46 for fronts and $39 for the rear, of course confirm this with Greg.
    And if you have any mechanical knowledge you can do the discs yourself. Just take wheel off, take two bolts holding caliper off, slide caliper off disc, slide old disc off, and reverse for install. Of course change pads at the same time. Just take one bolt off caliper, top pivots ups, just take old pads out and put new ones in, and reverse. Really once you have the wheel off, it takes no more that 15 minutes a side.
    May 2009
    Melb, Vic
    02 VY SS
    Apr 2010
    easy as to do just remember to have the handbrake off and re adjust if neccasarry after re fitting new disks. you may have to back the hand brake off a touch to get the disk off though
  1. rotor machining
    By luvmycommodores in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2010, 01:40 PM
  2. V8 Block machining
    By stocky in forum The Pub
    Last Post: 27-11-2007, 09:04 AM
  3. VK Stock drum and disk setup to a VT disk setup
    By justinp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-02-2006, 09:37 PM
  4. VS 95 wagon, diff / rear end disk - disk
    By digisol in forum Swap / Wanted to Buy / Trade
    Last Post: 27-11-2005, 06:05 PM
  5. FS: VY 6 Disk CD Player
    By VY2ENJOY in forum Parts And Other Items For Sale
    Last Post: 08-08-2005, 12:22 PM
