Results 1 to 5 of 5
Thread: VY brake noise
    VY executive ute s1
    Jan 2009
    Default VY brake noise
    I hear cars with them all the time, an intermitant shh, shh, shh, shh, shh. It changes when the car speeds up or slow down
    Some people say its because people drop the wheels on the dust cover and it hits the disk, but to me if that was the case with mine it would be a constant shhhhhhhhhh
    Only other idea is that the rear brakes are warped. Is this the obvious case or can this also be something much more serious??
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Mine did this after i changed my calipers to bigger ones. Turns out the shims that hold the pads in were bent a little and hitting the disc making the shh shh shh shh shh noise.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If it makes a shh shh shh noise as the wheel turns, then the rotor isn't perfectly straight. It's just the sound of the pads touching them, if the steering wheel or the brake pedal doesn't vibrate under brakes it is fine.
    Visit my Facebook page
    WH caprice , 2010 Holden CDX Cruze
    May 2008
    my vy made this noise when i first bought it took it back under warrenty turns out the hand break assembliy was faulty and was grabing the back breaks just slightly reajusted and havnt herd it since only noticied it when driving threw mcdonalds drve threw lol shhh shhh shhh shhh shhhh noise
    Dec 2009
    Quote Originally Posted by tyrone View Post
    There was a change to the hand brakes during the Vy production, the shoe can drag on the drum and make a scuffng noise so a bracket and spring were added to keep the shoe in the right place. You can buy the bracket and spring ina kit from Holden it has instructions on where to drill a hole inthe brake shoe but if this has been replaced since that mod then they will probably have the hole in them already.
  1. scratching brake noise
    By GAMBLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2009, 01:07 PM
  2. back brake noise
    By bluecar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2008, 04:51 PM
  3. Noise From the Brake/Tyre
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-07-2006, 09:48 PM
  4. Rear Brake Noise -- HELP --
    By U2Bono in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-10-2005, 11:16 AM
  5. brake pad warning noise?
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-10-2005, 07:45 PM
