Results 1 to 4 of 4
Thread: Clunking coming from front end when turning and going up a curb
    VY Equipe
    May 2010
    Default Clunking coming from front end when turning and going up a curb
    I have a Clunking coming from front end when turning and going up a curb. I supposebly had it fixed during the last service by replacing a split engine mount, but it only got quieter to start with and now is getting loader again. They checked the shocks which they said were fine, but could they have just tightened up the shock during this inspection which solved the problem and then changed the engine mount anyway. Maybe the shock has worked loose again.
    Dec 2009
    Have you checked your front sway bar link pin bushes where it connects to the strut? These can squash up and come loose. Mine will need changing at the next service. You can buy the 4 of them from Holden for about $10.00
    VY Equipe
    May 2010
    Quote Originally Posted by wortus View Post
    I haven't as yet. I've seen a a few other posts that they have suggested a similar solution. Thanks
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    yeh dude, id check them exact problem i had, change the bushings and the noise is gooonnee!!!!
  1. clunking noise when turning left
    By Trewman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2010, 10:22 PM
  2. High pitched sound coming from front left wheel when turning
    By RonMan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2009, 10:45 AM
  3. clunking when turning
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2007, 03:39 PM
  4. Clunking when turning...
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2007, 11:57 PM
  5. turning clunking
    By alex88 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-01-2006, 11:12 AM
