Results 1 to 12 of 12
Thread: 6 speed in a v6
    2002 vy commodore ute
    May 2010
    Default 6 speed in a v6
    does any one know what is needed to fit a 6 speed out of a ss vy into a vy s (v6) it is cerrently a auto but hopefully soon it will be an manual but would like to get a 6 speed to put into it .
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    The bellhousings are completely different, so you need to get a 6 speed manual case/box from a dedicated 6 cyl.
    There is no such thing as stupid questions, Only stupid people.
    VS L67
    Sep 2007
    BrisVagus
    Mal Woods Automotive do a kit for the 6 speed T56 to go behind a V6 ecotec. You will need pedal box, clutch master cylinder, flywheel and clutch, new gearbox cross member, modify your tail shaft, change some wiring on the gearbox loom, change the speed sensor settings in the ecu modify the console and the plate were the shifter comes through and wire up the reverse solenoid lock out.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    May 2010
    ok then do u know how much the 6 speed kits are ,yeah i done a conversion little while go on a vp ute v6 but sounds like a little more work with the vy
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    You do realise that if you do this your ute will be an absolute slug. T56 gears are a fair bit taller than the getrag 5 speed - 6th will be unusable.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    May 2010
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    6spd will work but you'll need some pretty short diff gears.. meaning 1st will be pretty well useless I would suggest :P
    Go with the 5spd, not enough results to justify the outlay getting a T56 in there.
    Sam
    WTB: mulberry VN interior parts
    VY SII HBD Calais L67
    Dec 2006
    A T56 and 3.93:1 gears will liven up any VY commo to no end. If you have the coin and really like the idea os a 6 speed then go for it I reckon.
    Decicrate has been running a T56 behind his L67 for years with no dramas that I know of other than a lighter back pocket
    http://www.youtube.com/watch?v=xfSmo...eature=channel
    VYII Calais L67
    Mar 2008
    Mal wood T5 kits are fricken awesome - i can vouch for them personally. I think it's about $5500 for the box, but if you want to do it properly it's going to cost you. Getrag conversions are significantly cheaper - i see them on ebay every now and then for about $1500 for everything.
    Dec 2006
    Quote Originally Posted by one_and_only2004 View Post
    We aren't talking about a T5 kit here. T56 seems to be the poison of choice. Chevtorque, Mal Wood and Dellow do bellhousing adapters for the V6
    VYII Calais L67
    Mar 2008
    Quote Originally Posted by chargedvx6 View Post
    I know we're talking about the t56 but it's a complete waste of time on a NA ecotec - they just don't have the go about them to make use of a 6 speed.
    VS L67
    Sep 2007
    BrisVagus
    AS chargedvx6 said, with the right diff gears and the right T56 you can get the N/A 6 going pretty well. It does come down to how much money you want to spend.
    With a N/A the T5 won't have any hassles wit it putting up with some savage abuse, stay well away from the GETRAG, they are just to expensive if you have an issue, but they are a very light gearbox.
    My T56 set cost about $7000.00 and this was with me doing the fitting and making all the small mods that no-one tells you about, like floor clearance exhaust mods getting the box to sit on the right angle so the tail shaft stays in perfect alignment.
    The box is also a Road Race box hence the extra cost.
  1. Question on changing from 5 speed to a 6 speed
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2010, 08:30 PM
  2. Replaced Cluster and Speed Sensor, still won't show speed - only in ALDL
    By VS Omega in forum Electrical Wiring / Questions
    Last Post: 24-04-2009, 06:39 PM
  3. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    By quick202 in forum Swap / Wanted to Buy / Trade
    Last Post: 05-10-2005, 11:12 PM
  4. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    Last Post: 05-10-2005, 11:01 PM
  5. digital speed read out in VS with speed alert
    By vs0001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 06:09 AM
