Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: exec petrol consumption
    VY Executive S2
    Jan 2010
    Default exec petrol consumption
    i know theres a fair few of these threads floating around but i couldnt find it.
    im averaging 14.4 ltrs/100km in a stock exec. i pump up my tyres every 2-3 weeks and use shell unleaded. i used to get around 12 to mid 12/100kms.
    also this might sound like a stupid question but is there a way to turn the aircon/heating off completely rather than just have the fan on? or is putting the thermostat to the middle the only option?
    WH caprice , 2010 Holden CDX Cruze
    May 2008
    i had the same issue as yours with fuel economy mine slowly got worse at its worst mine was well over 20l per 100 all i did was change the airfilter mine is back down to 11l per hundred now cost me $8 and paid for itself in the first 100km i did lol
    VY Executive S2
    Jan 2010
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Unhappy
    Quote Originally Posted by danieLOL View Post
    Engine air filter elements should be changed every year for optimum efficiency and obviously more often if driving in dusty conditions.
    The aircon is always completely off until you press the aircon "button" to activate it. So just make sure the button is off. If it is not off the air con will start running every time you turn on the fan.
    Heating uses no power because it is produced from hot engine coolant being circulated through the heater core. The coolant flow is turned off when the temperature dial is switched over to the cold setting. You do not have to turn on the electric fan for heat but the heating will not be very effective just relying on flow through air entering the vehicle when you are moving - with the vent system open.
    If you are unsure of the operation of the controls on your dash consult your owner's manual.
    VY Executive S2
    Jan 2010
    nah i know how to work it i just thought maybe it was using petrol from having the fan on because heat was coming through, but thanks for clearing that up
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    well if you think about it, having the fan on would use a tiny bit more petrol, as it needs power to power the fan which comes from the alternator, but stuff all really lol ... i dunno why your engines sucking up so much petrol tho, is the 14.4/100kms on freeway or city driving? ..
    mine does about 6.9/100kms on freeway n about 10.8/100kms in the city. and round 8.7/100kms average,
    have ya checked ya oxygen sensors?? ive found that to be a pretty bad problem with sucking up heaps of petrol, and what octane petrol do ya use? .. maybe the petrol your using is really crap quality and burning extra quick? .. I use that United petrol and ive found for some reason it works heaps better than mobil or shell petrol?
    VY Executive S2
    Jan 2010
    ummmm probably half freeway/half suburban. it dropped down to 14.1 today but thats still too much.
    a mate from work told me to check those sensors but i wouldnt have a clue what im looking for though lol
    and i fill up with shell unleaded. ill give it another go next week when i fill up since ill get a new filter and see how i go, if not ill try a diff fuel
    VY Exec & VZ Calais
    Mar 2010
    I do half half driving as well and I average around 8.8 to 9.2 depending week to week.
    Also, I keep mine serived every 10k, both oil and filter, and every 30k change air filter.
    Just keep in mind though the trip computer display can be out somewhat, as mine sits around the 10.5 to 11.0 mark, but am not using that sort of fuel.
    Economy Calculator
    I use the above fuel calculator I saw on the net, easy as to use, and will REALLY work out your consumption.
    VY Executive S2
    Jan 2010
    VX II Calais L67 Manual 17 PSI W2A + MAFLESS
    Apr 2009
    Hey Mate, i got improved fuel economy from making a second hole mod in my airbox (http://swingtan.customer.netspace.net.au/2hole.html)
    And by modifying the stock over the radiator intake pipe [http://autospeed.com/cms/A_109586/article.html]
    Hope these help,
    Shaune
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Unless you have a fault with the engine management system or your vehicle's fuel system has been poorly maintained, then fuel consumption is linked more to how far and hard you press down on the accelerator. If you seeking to improve your fuel economy and of course once your car is running in accordance with manufacturer's specifications, try using the acc. as if you have an egg under it and you don't want to smash the egg by abruptlly pusing the pedal down. Bet you find there is an improvement.
    Feb 2010
    Central Victoria
    haha yeh benboy's got that right, you'd get probably twice as much km's outta a tank if you dont always wanna be first off the mark at the traffic lights lol
    VY Executive S2
    Jan 2010
    that 2nd hole mod looks like a lot of fiddling around, the intake hole i might give a go since it looks fairly simple.
    i filled up on wednesday and with the new filter its dropped down to just under 13, ive only done 70ks though so i'll see how it goes
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    Hmm i bought my VY S 2 weeks ago and it seems to average a lowest of 14.5l/100ks.
    It was 18.5 at one stage, maybe I'll do the filter and sht also.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
  15. #15
    Harrison's Avatar
    Harrison is offline Donating Member
    04' VYII 3.8L A4
    Sep 2009
    Mount Isa
    Yeah I used to get alot better economy to what i get now, i clean my filter once a month when i do a check on everything in the car and clean out the engine bay, lately i've been getting say 400kms to a tank i used to get way more, but i drive alot harder now because i drive less, so i kinda make the most of it
  16. #16
    VY Executive S2
    Jan 2010
    Quote Originally Posted by Benboy View Post
    ok so i tried driving like a granny for about 20 or so ks earlier this evening and **** me did it make a difference, it dropped like .5 of a litre in the span of a about half an hours worth of driving..... i knew it'd make a difference but not that much :O
  17. #17
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    02 sensors are due for replacement after 120,000 k's. Or so I've been told, soon to do mine as I've done that many k's. However, I still get around 8l/p100 on the freeway AND 9-10 around town. Air filter changed every 20,000 and spark plugs, too. Same for fuel filter, seems like very poor fuel economy unless you're flooring it each time you take off!
  18. #18
    VY Executive S2
    Jan 2010
  19. #19
    Feb 2010
    Central Victoria
    id say your looking around $50-$70 depending where ya buy em dude... and im pretty sure you need to get 2 of them aswell if your cars anything like mine, so round 100 bucks say..
    but yeh driving like a granny isn't all that bad haha,
    i don't understand why everybody's readings are so high!!.. i get about 14/100km's if i'm lucky if i wanna be a racecar driver.. not that im complaining i just dunno why? lol
  20. #20
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    how much am i looking at to replace them?
    I've phoned a few auto shops and yeh 70 odd bux each on average here in Bundaberg. Depends on the brand, though, some a bit more/bit less. There are two, so double whatever price you're quoted for each.
  21. #21
    Feb 2010
    Central Victoria
  22. #22
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by a1k3m1 View Post
    Me too, i rarely to get over 12L/100k, usually sits around 11L/100k. Even blasting through the Black Spur at Marysville it returned 11.8 or something like that .
  23. #23
    Feb 2010
    Central Victoria
    haha i went roaring down there once, n neally got cleaned up by a log truckie lol.. never again lol that was too scary hah
  24. #24
    vs executive s2
    May 2010
    STOP using shell petrol . its crap.......
    Try using high octane for awhile to clean the fuel system.
    Cheers KBELT
  25. #25
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    It's worth noting you should go on ebay and get yourself a tune from the user 'nicefrog', our very own greenfoam (who has abandoned ship so don't PM him lol)
    Intake, exhaust, tune saw my v6 auto VN sit under 7L/100km on highway trips, and around 11L/100km around town. Pretty fantastic for a 20yo car.
    DEFINITELY worth the $50 or whatever he charges for them these days.
    Send him a message on ebay even if the tunes he has listed don't match your car, tell him what you want and he will sort you out.
    Sam
    EDIT: my bad didn't see this was a VY. = does not apply. VN-VT nicefrog is your man
    WTB: mulberry VN interior parts
  1. VZ exec rear bumper on VY exec
    By VjamesY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-05-2010, 11:38 AM
  2. gas consumption
    By scottyz999 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-02-2010, 03:40 PM
  3. VY V6 oil consumption!!!
    By oilburner681 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-08-2006, 09:35 PM
  4. GAS consumption
    By comtim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2005, 02:55 PM
  5. Bad Oil Consumption
    By zoidberg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2003, 04:48 PM
