Results 1 to 10 of 10
Thread: Fuel Pump upgrade
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Default Fuel Pump upgrade
    Turns out that after I whack all these bits in my ute I'll be needing a larger fuel pump. Is there a straight drop-in replacement for the old shock-o-tech VY V6?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I believe Walbro make a higher flowing pump. Or wouldn't an L67 pump fit?
    Ronald Reagan (1986)
    Mar 2008
    I didn't think about an L67 pump. Are they any better or just the same?
    VY II V6
    Dec 2006
    You're better off going for a bosch or walbro high-flow equivalent. Apparently the L67 pumps need a little more than bolting them in..? Something to do with the 2 speed controller for the pump???
    VS V6 T5 & VY V6 M35 UTE
    Oct 2004
    Jurien Bay WA
    Quote Originally Posted by one_and_only2004 View Post
    Don't bother trying to fit a genuine L67 fuel pump as the VY utes Swirl pot is different to the sedans. The L67 Swirl Pot from a sedan wont work in a ute & the L67 pump is of a smaller diameter & has a second venturi jet pump intake to the L67 swirl pot. To much trouble to convert. The Walbro 255 LPH High Pressure pump is the best one to fit in place of your stock fuel pump. Make sure you get the F20000169 model walbro intank pump as it has the fuel pump inlet & offset sizing correct to the same as your stock pump.
    Either that or install a surge tank set up & a Bosch 044 offf that using your stock pump as the surge tank fill / lift pump.
    Deek
    Aussie Aussie Aussie, Oi Oi Oi .
    Mar 2008
    OZ38, you've made my life a fair bit easier. Thanks for the info!
    blown vy v8 ute
    Jul 2009
    i had a walbro intank in mine mate .. you shoud be set with that ... easy replacement
    Oct 2004
    Jurien Bay WA
    Your more than welcome.
    Deek
    vz ss and vs statesman
    Mar 2009
    How did you get the plastic case off the sender unit to get to the fuel pump and the filter in the tank? Does any one know? I just want to replace the pump and filter in the tank but cant get it out of the sender unit. If any one knows what im on about. The sender unit is out but i cant dismantle it enough to get to the pump itself. Thanks
    Mar 2009
    Its a vz commodore by the way but it should be similar shouldnt it?
  1. Fuel pump upgrade?
    By gary in forum V8 Development and Modification
    Last Post: 23-01-2010, 09:10 AM
  2. v8 water pump upgrade 383
    By pazy_699 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2010, 01:12 PM
  3. Bosch 040 Fuel Pump Upgrade
    By muttley383 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2007, 08:01 AM
  4. Oil pump and timing upgrade.
    By traindriver in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-05-2006, 02:09 PM
  5. VT 5L: Upgrade fuel pump?
    By klue in forum V8 Development and Modification
    Last Post: 23-05-2005, 07:44 PM
