Results 1 to 9 of 9
Thread: vy horn sounding when lock button is pressed
    stooie's Avatar
    stooie is offline Stui
    vy executive series ll
    Sep 2009
    Shepparton
    Default vy horn sounding when lock button is pressed
    when i go to lock my car the horn sounds in 4 quick beeps, i have heard that it may be the actuator. How do i find out which door it is???
    VYII Berlina 3.8, VE Calais V 6L
    Aug 2005
    Quote Originally Posted by stooie View Post
    Take a look at each door after you have pressed the lock button and see which one hasnt gone down. The horn basically signals that either the actuator has gone (in which case the door cant lock) or a front door is ajar whilst trying to lock it (also meaning the door can't lock). Rear doors will lock whilst open, however I don't know if the horn will signal when an actuator goes in the rear door. Anyway, best chance to find out whats going on is to look at each lock on each door when you lock it, the lock that doesn't go down is your faulty one.
    Ben
    stooie's Avatar
    Sep 2009
    Shepparton
    Quote Originally Posted by dah_man_ben View Post
    Ben
    Ok thanx mate i try that, wouldu have any idea of wat a new actuator would cost?
    Aug 2005
    I got one of mine done at holdens about six months ago. About $200 mark from memory. The receipt is filed away, cant be bothered finding it lol.
    Probably marked up 100% knowing Holden.... Ask around at some local garages for prices, as it is a common problem.
    VS SS
    Mar 2009
    should be around $30 from a decent wrecker.....otherwise ebay even cheaper
    vy s ute series II 2003
    Dec 2008
    did you ever play around with ur wiring i had the same problem coz wen i bought my car all the cables were cut and i resoldered everything then it made that sound then discovered that the 2 of the 3 grey wires were connecteed incorrectly
    VY SS commodore
    Aug 2008
    Perth, Western Australia
    you can set it to sound the horn when locking/unlocking the car in the menu. does it still sound when you deactivated that?
    Dec 2009
    If it went to a dealer you should check the plastic seal behind the door card has been replaced properly otherwise it can leak.
    stooie's Avatar
    Sep 2009
    Shepparton
    Got a new actuator from senatormike and installed it last week, all works good now and only took about 25 mins
  1. horn button?
    By tommo123 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2010, 04:13 PM
  2. Broken Lock Button
    By mainpath in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-10-2009, 10:02 PM
  3. WTF.....Horn sounding for no reason!!!
    By Oakey in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-09-2009, 08:42 PM
  4. Replacement Horn Button
    By Bax in forum General
    Last Post: 09-01-2008, 11:04 PM
  5. What does it mean when the horn beeps after i lock the car??
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2006, 07:55 AM
