Results 1 to 5 of 5
Thread: VY Air Con Smells
    Nov 2003
    Default VY Air Con Smells
    HI Guys,
    I have noticed that after using my air con, the next day when I turn on the fan it smells.... It is some sort of bad odor.
    Has anyone else copped this? If so how did you rectify it?
    Regards,
    Arty
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    VY Executive S2
    Jan 2010
    vy_storm's Avatar
    vy_storm is offline just another moderator...
    VE Calais V 6L
    May 2005
    the burbs of Adelaide
    Nope, you're not imagining it. It's due to build up of moisture/bacteria in the vents. When it gets fully cold or hot the smell goes away, but will continue to build up when there is condensation and no air moving through. Have heard it referred to as "bum smell" but that's a bit harsh, lol.
    If you can find an easy way to get rid of it, good luck. There are some commercial products available that squirt down the vents to kill the stuff that causes it, but not readily available from searches I have found.
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    With the aircon off and the thermo turned to the full hot setting, run the vehicle for a while on medium to high fan with exterior air flowing through the heating and vent system(ie. not in recirculating mode). Have a window part open at the same time.
    This helps to dry out moisture build up in the ventilation system.
    BTW, if you run the aircon with recirculating air too often (ie., in the recirc mode air setting) rather than mostly allowing an exterior air flow through the system you will usually get a larger odour problem in the car.
  1. car smells like a BBQ
    By m05tw4nt3d in forum VE Holden Commodore (2006 - ?)
    Last Post: 25-12-2009, 08:32 PM
  2. Smells of Petrol
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-12-2006, 01:55 PM
  3. Smells Like ...?
    By HER82 in forum The Pub
    Last Post: 07-11-2006, 09:34 PM
  4. smells like S*#T
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2006, 01:21 PM
  5. My VN oil smells burnt????
    By V8commodore_chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2005, 11:45 PM
