Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By MAG00
Thread: Drivers window rattle
    Hot House VY SS
    Jan 2010
    Default Drivers window rattle
    Hi
    I've got a fairly annoying problem with my drivers side window in that when its part way down it rattles when driving along. There is some movement in the glass as you can move it in and out probably about 5-10mm.
    Just wondering if anyone has fixed this problem and can let me know how I can do the same? Is it a matter of replacing a certain part in the door or another simple fix?
    VY2 Berlina
    Jun 2008
    Castle Hill
    Hot House VY SS
    Jan 2010
    The rattle happens whenever the window isn't shut, so dropping it doesnt change anything.
    Basically the key to removing the rattle is getting rid of the sideways movement in the glass.
    Is there something in the door which holds the glass that could wear out?
    wetwork65's Avatar
    wetwork65 is offline A wet business
    VY Berlina V8 & VZ Adventra LX8
    Mar 2006
    With the goblins in South West WA
    May be the window channel slides - they sit in the horizontal track under the window glass and break after a certain length of time. They look like white platic nutrigrain, approx $4 ea from Holden parts. They snap onto the pins on the ends of the window actuator arms inside the door - I found vise grips or a G clamp will be neded to push the new plastic parts onto the pins.
    Will have to take the door trim off and move aside the clear plastic sheet behind trim to access the slides.
    There are a few threads on this elsewhere - I have done this job on about 4 cars so far.....
    Hot House VY SS
    Jan 2010
    Hot House VY SS
    Jan 2010
    Finally got around to doing this
    How do I actually remove the window channel slides from the actuator arms? A bit hesitant to try and prye them off as I dont want to break the glass!
    Hot House VY SS
    Jan 2010
    Or to put it another way, do I need to remove the actuator and/or window glass to change the slides?
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    VY S/II S Pack
    Apr 2011
    Quote Originally Posted by Nic92 View Post
    i've noticed my window rattles when i go over bumps and that, when its half down
    Oh wow, you're kidding right?
    VY SS
    May 2011
    Auckland
    My vs did this. Had to re glue the seal that holds the window out from the inside inline with the top of the door card. if you look down the window there's about a 10mm gap on the inside.
    When my olds owned it they used to get Holden to re glue it every 24 months from new.
    Havnt had the same problem with my vy though. If its the same then it's an easy fix
    2003 VY SS series 2
    Sep 2009
    Brisvegas
    You could always just leave it up and use the ac? Or have it all the way down?
    Hot House VY SS
    Jan 2010
    Well if it involves having to drill out the rivets that hold the actuator in the door to remove it, then yes that will be the solution!
    2003 VY SS series 2
    Sep 2009
    Brisvegas
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    My window does the same thing.. Must be a common problem on the Vy's..
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
  15. #15
    VY S/II S Pack
    Apr 2011
    My window makes a slight rattle when exposed to bumps or high frequency music, I will investigate it sometime soon and report back (have year 12 exams next week, so it's not really high on my to-do list).
  16. #16
    2003 VY SS series 2
    Sep 2009
    Brisvegas
    pfft exams... Schools for suckers lol Nah, study is more important than cars if your going for your HSC
  17. #17
    Ignited-SV6's Avatar
    Ignited-SV6 is offline Sleek and Class
    VY Berlina
    Jun 2010
    My window makes a squeek noise even when its closed....sounds like any minute its going to fall off. pisses me off.
    Even when im going slow and brake slowly it sounds like its moving forward slighty. doesnt sound tightly fit.
    Do we think the auto elec will fix this for me?
    My Ride
    http://forums.justcommodores.com.au/...a-ss-rims.html
    Next mods: Lowering, 4 Channel Amp and eventually 19's
  18. #18
    Hot House VY SS
    Jan 2010
    Auto elec? Probably not, read the 4th post in the thread. May also be loose window guides (vertical) in the door.
    Can anyone actually say how to remove the channel slides? I think the actuator has to come out, just need confirmation
  1. how to stop window rattle??
    By Escape-The-Fate in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-01-2010, 03:24 PM
  2. window rattle
    By cewing in forum Car Audio
    Last Post: 18-08-2008, 12:31 AM
  3. VS Calais Drivers Side Rear Door Rattle and Clunk
    By Sara Pax in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2008, 06:35 PM
  4. Drivers window rattle
    By vz 914 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-12-2007, 08:03 AM
  5. Drivers Window Squeak/Rattle
    By dtrain in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-02-2006, 03:24 PM
