Results 1 to 5 of 5
Thread: Buying and installing footwell Neon to VY Ute
    VY ute (2003)
    Jun 2010
    Manly
    Default Buying and installing footwell Neon to VY Ute
    Hey guys,
    I am based in sydney and i want to install blue neons under my dash and glovebox. Just wondering how i would go about doing so and where is a good place to go to buy the neons? (cheap)
    Thanks
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Do you have supacheap auto.. Really we can't do all the work for you.. If it's a bog standard (pov pack) you'll need to wire up to the O-BK cable. They draw minimal amount of amperage so there won't be no drama's there. Or you might be lucky enough to have less than bog standard wiring and have in place plugs behind the panels all ready for the 5watt wedge globes.. more than likely taped central on both sides.
    Cheers,
    Dave
    Junny's Avatar
    Junny is offline purrrrrr
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    Quote Originally Posted by caaf View Post
    search up phreddy on the forums... he did my old ones for 15(?)each it was either 10 or 15... NOT SURE so dont take my word....
    his got ones u can adjust colours now as well ....
    VY executive ute s1
    Jan 2009
    just stick them where you want them and splice into a powerwire easy peasy. if you want to run them off a switch, wire the switch throught the ciggi lighter power, if you want them running when the door is open, splice into the wire that comes from the door switch. Just find the colour and away you go
    VY ute (2003)
    Jun 2010
    Manly
    Awesome, I wouldn't mind giving it a go myself to be honest.
    Just a bit reluctant pulling pannels off and damaging the plastic
    Ill drop by Supercheap and see if i can get them. Worried they will be over priced though
  1. Footwell Neon / Leds
    By Josheh in forum Electrical Wiring / Questions
    Last Post: 08-06-2010, 06:37 PM
  2. footwell neon help..
    By vk.jonno in forum Electrical Wiring / Questions
    Last Post: 15-11-2009, 10:20 PM
  3. installing footwell neons help
    By Salmon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2009, 07:49 PM
  4. Neon lit footwell
    By Matt02SS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2009, 10:19 PM
  5. VE SS - Installing Neons(Footwell)??
    By hdg_05 in forum Electrical Wiring / Questions
    Last Post: 18-08-2009, 09:31 PM
